vin code translation
Old Dec 28, 2003 | 03:50 PM
tm winchester's Avatar
tm winchester
The vin #is 1TEF14HOFPA0XXXX, any help would be appreciated
Old Dec 28, 2003 | 05:08 PM
hoxiii's Avatar
hoxiii
That's not your vin, yu only have 16 digits, it should be 17. BUT i think I can figure out what you have using some common sense.
It should probably be
1FTEF14HOFPAXXXXX
1FT=Built by Ford USA as a complete truck
E=6,001-7,000 lb brake and springs
F14=F-150 4x4
H= your motor (don't have the exacts for "H")
O= a check digit, no biggie
F=model year 1985
P=assembled at twin cities
A=first run of 99,999 trucks for the year
XXXXX= consecutive unit built
Justin
Old Dec 28, 2003 | 06:12 PM
tm winchester
sorry its 1FTEF14HOFPAOXXXX i AM LOOKING FOR THE ENGINE CODE TRANSLATION.
Old Dec 28, 2003 | 06:52 PM
hoxiii's Avatar
hoxiii
Well, I can tell ya that H isn't for the 300, so for an '85 F-150 that leaves the 302 and 351 V-8. I'm sure someone can ring in and tell you how to tell the differecne between them (if that's what you're looking for). If you want to know the original motor in the truck then you need someone that knows "H".
Justin
EDIT: in 1985 the "H" is for the 351w HO 4bbl
Old Dec 28, 2003 | 07:27 PM
tm winchester
I havent got into the truck mutch it had a tore up 3rd member and I bought it for 275.00 the body is cherry. White shortbed fleetside. There is an adapter under the carb {2 bbl } Im hoping I see 4 holes under that adapter.Thanks for all your help Justin it is appreciated.------------------------------------------------------tom
Old Dec 28, 2003 | 08:32 PM
bobcf's Avatar
bobcf
87-96 h = 351w
If it is the same in 95
Bob
Old Dec 28, 2003 | 08:33 PM
Franklin2's Avatar
Franklin2
carllouis
Mar 23, 2017 04:11 AM
6cannons
Mar 11, 2013 07:47 AM
OhioRiverCigarette
Apr 4, 2008 04:19 PM
Sawsall
Feb 11, 2008 11:01 AM
timpage
Mar 5, 2000 12:48 PM
