5 speed probs
Old Dec 28, 2003 | 01:22 PM
93fordlighttruck's Avatar
93fordlighttruck
5 speed probs
i have a 93 ranger 5 speed, i replaced the clutch about 4 monthes ago, and recently it has become difficult to shift gears. i replaced the transmission fluid, and double checked the clutch master cylinder but everytime i try to shift, i get a grinding noise, with effort i eventually get into gear but sometimes i have to shut off the engine to shift into first when i am at a light, does this mean the trans is going out, or is it that a mistake was made putting the new clutch in???
Old Dec 28, 2003 | 01:59 PM
Dealford's Avatar
Dealford
Welcome to FTE 93fordlighttruck.
First apply the "KISS" rules.
Is the clutchs' hydraulic system working properly?
Has the system been bled lately?
Is the sleeve that the slave/throw out bearing assembly moves on properly lubricated?
Have you tried pumping the clutch pedal before putting the trans in gear?
Old Dec 29, 2003 | 03:59 PM
4x4ranger01's Avatar
4x4ranger01
I had that problem when I first got my 01 Ranger edge 5 speed. It would grind and not wanna go in gear when i would shift into third and when i down shifted to third. It turned out that I had bad Syncronizers in the tranny so warrenty gave me a brand new tranny. I would check the tranny. Hope this helps.
Old Dec 29, 2003 | 10:21 PM
Hank85713's Avatar
Hank85713
Id say 2 real possibles here. 1 is a bad master or slave cylinder, maybe both you didn't say if you R&R them. 2d is that the pilot bearing is shot.
I just pulled my trans for a 5th gear R&R and the pilot bearing was toast. Scored the mainshaft but the shop was able to polish out.
so if you did not R&R the hydralics that is probably the main problem, so out comes the tranny again for the slave cyl, so while its out look at the pilot bearing, for around $15 replace it and add a little extra grease to it to boot.
The master is fairly easy to R&R, just time consuming to get bleed unless you do as I do, but that is something we can help with later.
hank
Old Dec 30, 2003 | 06:52 AM
93fordlighttruck
what is the easiest way to bleed the system, someone else did it when the new clutch was put in
Old Dec 30, 2003 | 09:57 AM
Hank85713's Avatar
Hank85713
It is supposed to be a gravity bleed of the system at the slave. If you have air in the master it really is a pain to bleed it out. Here is how I bleed the master:
inside the cab, pull the starter interlock from the clutch rod, disconnect the rod from the pedal arm. You will see a circlip in the master over the piston. Pull the circlip, pull the piston till just the air and a little fluid escapes, pump the master a couple of strokes repeat the above, reasemble than bleed per the manual, open the bleeder and let gravity bleed. Might have to bleed the bleeder a couple of times, biggest thing is the air in the master.
Make sure the resevoir stays full or you will into air into the system.
A lot of folks blame the slave, but the master is also a likely culprit.
Old Dec 30, 2003 | 02:03 PM
racsan's Avatar
racsan
i had a similar problem with my old '88 ranger, turned out one of the hub dampner springs broke, and a peice of it was between the pressure plate and clutch disc. this was with a 2.3 motor. dont know why it happend, stock clutch had gone 145,000 with no problem. i only changed it for "insurance" since i had the motor out for an overhaul. never buy a relined disc iguess.
Old Jan 1, 2004 | 04:47 PM
modeltford's Avatar
modeltford
I have a 93 Ranger, 4.0, 5-speed with 185000 miles..... Have a problem with clutch not releasing completely, mostly in cold, damp weather. I'll come to a stop in traffic, and it will creep - try to pull out of gear and find it can't be done - act's like clutch is partially engaged. Could this just be a hydraulic pressure leak?? Doesn't always happen, but almost always in colder weather, NOT in warm........ I've had truck about 2 years, and don't know if anything's been done to clutch/trans.
Broncoslocos
Apr 8, 2015 12:20 PM
Josh Holliday
Oct 3, 2012 11:28 AM
yeoldethings
Jan 13, 2005 04:38 PM
kasejust93
16
Mar 1, 2004 11:52 AM
newtattoobob
Nov 28, 2002 09:37 PM
