1978 - 1996 Big Bronco
bronco starter solenoid
Old Dec 28, 2003 | 10:34 AM
fordguy351w's Avatar
fordguy351w
sometimes my bronco will not start off the key ignition so i have to jump the terminals on the soleniod. is it just the solenoid? or is there something else that needs attention?
Old Dec 28, 2003 | 12:26 PM
randomdansucks's Avatar
randomdansucks
I put in a solid state and it got rid of that problem. I check all your wiring connections for corrosion. If not fixed it can led to major electrical problems later.
Old Dec 28, 2003 | 01:12 PM
fordguy351w
what did that solid state cost you? easy to put in?
Old Dec 28, 2003 | 04:50 PM
Bailey's Avatar
Bailey
Most likely the wires. It could also be the switch.
Old Dec 28, 2003 | 06:28 PM
John Pen's Avatar
John Pen
I think those starter solenoids are wear parts...defin. a cheap and quick fix...and if that dosent solve your problem..at least you've saved a problem down the road...
Old Dec 28, 2003 | 06:47 PM
randomdansucks
It took about 3 minutes but make sure you disconnect the battery first and before reconnecting the new one either put on new ends on the wires or use emory paper (fine sandpaper for metal) to clean off the corrosion. I think it was under $15, my dad picked one up for me so I don't remember. make sure to get a solid state though
b.simone1210
Jun 23, 2013 12:13 AM
79 bronc
Electrical Systems/Wiring
Oct 21, 2007 09:11 AM
tr0y
17
Apr 4, 2005 03:48 PM
jims89bronco
Mar 22, 2004 12:26 AM
IMHIGH
May 10, 2000 04:15 AM
