Sponsored by: Real Truck
leveling kits and plows
Old Oct 17, 2002 | 05:07 PM
Gwilkrrs's Avatar
Gwilkrrs
does anyone know if a leveling kit wich replaces the srpring shackles instead of adding add a leves will effect the mounting of a fisher snowplow? i plan on ordering the shackle kit to level my truck (2002 crew cab 4x4 diesel) but want to make sure that they wont interfere with the plow mount.
Old Oct 17, 2002 | 05:30 PM
Yeti's Avatar
Yeti
Unfortunetly, I can't help you with the fisher mount, I can tell you after just looking at mine with a western, that their would be no problem with the shackle kit. My springs are well outside of my western frame and would have no problem running logner shackles.
Maybe Forty can tell you about a fisher frame and the location of it to the shackles.
Old Oct 17, 2002 | 06:50 PM
Gwilkrrs's Avatar
Gwilkrrs
i dont think it will be in the way but hopefully forty will help/
Old Oct 18, 2002 | 05:07 AM
Yeti's Avatar
Yeti
Jeez Forty, it's 6 in the morning, don't tell me your still sleeping!!
Just thought I would bump this up so Forty will read it.
Old Oct 18, 2002 | 06:27 AM
FortyFords's Avatar
FortyFords
:-X23 :-X23 :-X23 :-X23 :-X23 :-X23 :-X23 :-X23 :-X23 :-X23
I'm just getting up,gotta get my coffe .
The minute mount mounts just before the springs,if I remeber the crashbar bracket bolts have to come out and go back in ,I'll chk in a few minutes after java.
A plow on a diesel and a crew cab ,be careful ,I think we talked about this before!
Rich
Old Oct 18, 2002 | 07:45 AM
FortyFords's Avatar
FortyFords
Okay chkd my plow mount,the rear part of the mount should not be a
problem,the front part doesn't attach to the crash bar or the spring
shackles bracket,it has a piece that goes on the inside up an over
the frame like a clamp and one hole has to be drilled through the frame
or at least opened up to alow the size bolt to go through.
I have no idea what your lift kit spring shackle looks like.
I don't have a lift on my truck.
My suggestion would be ask the lift kit people if you could return it ,if it interferes with the plow mount,or put it on and ask the plow installers to work around it. anything can be done for $ as we know
I know Yeti and I could get in on there.
Rich
Old Oct 18, 2002 | 08:05 AM
Yeti's Avatar
Yeti
>Rich
Anything is possible with a chainsaw and zip ties!!
I can take pics of my mount,as it relates to the shackle, I wouldn't think a fisher frame would be that much different.
Old Oct 18, 2002 | 05:05 PM
FortyFords's Avatar
FortyFords
Yeah we did try to customize Monsta's bus ,and make it a superduty but
he got scared when you pulled out that Chainsaw.
wish they all coulda seen his face!!!!!!
Rich
Old Oct 18, 2002 | 07:21 PM
FortyFords's Avatar
FortyFords
Old Oct 20, 2002 | 05:11 PM
Gwilkrrs's Avatar
Gwilkrrs
thanks, im going to check with the plow man but they sais they didnt think it would interfere. they said i couldnt return the perches if they were in the wAy, once they are installed they are yous they said.
Old Oct 27, 2002 | 05:29 PM
Gwilkrrs's Avatar
Gwilkrrs
just to let everyone know, i installed the rough country leveling kit that is shackle kit and shocks. the kit went on easy and am completely happy with the end result! now on to plow shopping
Old Oct 27, 2002 | 06:57 PM
FortyFords's Avatar
FortyFords
I hope you have x springs under it ,having a diesel plus a crew cab up front puts the extra weight up there then add the plow.
I thought Ford didn't want plows on crew cabs?I would problaby put a 7.5
fisher on it, its not to heavey.
Just my $.02
Rich
Old Oct 28, 2002 | 05:27 PM
Gwilkrrs's Avatar
Gwilkrrs
no, i didnt get the x springs yet. the truck sits level now and i'm scared the x springs will make the truck sit nosen high without the plow, so im waiting on the x sprinhgs for now. im also looking at an 8' fisher about 8-900 lbs. ford frowns on plows on diesels because the weight front to make ratio is too high or close to too high with the diesel for safe braking in their opinion. i had a regular cab disel with 7.5 meyer and never had a problem. drive smart! i use rear weight to counter the ratio a little
Old Oct 28, 2002 | 05:42 PM
Yeti's Avatar
Yeti
