help please???
Old Dec 27, 2003 | 10:12 PM
ltfox's Avatar
ltfox
help please???
My 2000 explorer has been giving me trouble lately. On cold mornings it starts right up and hold a high idle for 2-3 seconds and then drops down and starts running terribly. It will usaully die if you don't keep after it. This will go on for a minute or two untill it warms up a bit. The check engine light has been coming on also, and the code it is showing is a "lean fuel mixture". Changed fuel filter, had fuel pressure checked out and it checked out ok. Cleaned the idle control. Just lately I took it to a mech. and he said I needed a "mass air flow sensor"??( right on the tube coming out of the air filter box). That ended up being 150.00 bucks for nothing. Any suggestions would be greatly apreciated! thanks
Old Dec 27, 2003 | 10:15 PM
ltfox's Avatar
ltfox
by the way its got the 4.0 sohc if it makes any difference.
Old Dec 28, 2003 | 05:12 AM
marragtop's Avatar
marragtop
Have you had the diag codes pulled, and if so what did they indicate. Hopefully, before you paid $150 for the MAF, the codes were pulled.
Old Dec 28, 2003 | 09:38 AM
ltfox's Avatar
ltfox
The mech. who pulled the codes told me that it was "fuel mixture too lean".
Old Dec 29, 2003 | 08:48 PM
BrianJ77's Avatar
BrianJ77
I had the same problem (and codes, lean bank 1, lean bank 2, multiple misfires) with my 4.0 SOHC. They replaced the IAC and the intake manifold O rings. The choke kicks in like it should now when the engine is cold. I also tried cleaning my IAC and it didn't help. Replace that thing and your problem will disappear. Good luck.
Old Dec 30, 2003 | 05:43 PM
ltfox's Avatar
ltfox
Dumb question maybe, What is IAC and where is it?
Old Dec 30, 2003 | 05:54 PM
spirit's Avatar
spirit
heig dude, sound like wires to me, check it out and then last, reset ecu by freeing the batt and then reconect.
Good luck
Old Dec 30, 2003 | 07:50 PM
BrianJ77's Avatar
BrianJ77
The IAC is the "idle air control valve". The IAC controls the flow of air/fuel into the engine when the main butterfly valve is completely closed (accelerator not being depressed in any way/engine at idle). If your IAC is faulty as mine was, it will remain in the low idle setting and not adjust for low temperature starts and increased load.
The IAC is located on top of the intake manifold (beneath the plastic cover). It is held in by two bolts, is cylindrical in shape, and has a set of wires connected to it. See the sticky at the top of this forum and you'll get a good idea of what I'm talking about.
Some folks have tried to clean their IACs (including me) with carb cleaner. For some, this works for a while. It did not work for me and everyone will eventually have to replace it at some time in the life of their truck. Its best to get it out of the way and buy a new IAC. You can find one at most auto parts stores for about $70. I hope this helps. Definitely go to the IAC repair help sticky on top of this forum. Good luck!
Old Dec 30, 2003 | 10:12 PM
ltfox's Avatar
ltfox
I really thank you all for the help. That sounds like the next thing I'm going to check. One more comment though, When the explorer is running rough on startup, I can unplug the mass air flow sensor and the engine smooths right out. I replaced that sensor and it still does the same thing. Does this change anything???
Old Dec 31, 2003 | 04:48 PM
ltfox's Avatar
ltfox
Did the check on the IAC. Check out ok.
