Engine surging / acceleration when cold
Old Dec 27, 2003 | 03:57 PM
mdg97222's Avatar
mdg97222
hey guys !!
i love this site, found many solutions to various problems
My latest problem (ongoing) to fix with your help is
a surging/ acceleration when the engine is cold it happens every few seconds about the same ammount kind of like...
"RUUUUM........RUUUUM........RUUUUM... ect
you get the point heh.
it happens in all gears and gradually reduces untill it warms up
ANy thoughts???
thanx guyzzz
marrc
Old Dec 28, 2003 | 09:30 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Mine loped like that from time to time, not sure what it was.
I can also say that mine never did it when it was plugged in for the night.
I had about 245,000 on mine when it started to do this, how many do you have on yours?
I can tell you all the old Detroit Diesels (6V53, 6V71, 8V71, 8V92) had the same loping when they were cold. It smoothed up as the engine got to operating temp. Those were all 2 stroke diesels that ran for a boat load of miles, many still are.
Old Dec 28, 2003 | 01:17 PM
Dave Sponaugle
I just talked to a friend that had this problem on his 6.9. He took his injection pump to get it rebuilt and they found a shaft in the governor part of the pump that had grooves in it where an O ring rode on the shaft. Evidently when the O ring was cold it was crawling into the grooves and hopping out of the grooves causing the lope. A new shaft fixed the problem. They thought it was just an aggravation that would not affect the performance of the motor or how long it would run.
Old Dec 28, 2003 | 10:44 PM
mdg97222's Avatar
mdg97222
Dave,
thank for your reply!
hey I have 190k on mine old beast, no your right it doesn't seem to affect the drivability when its warmed up, the main concern i have is safety when its "loping" and in gear untill its warm which takes awhile, It does not have the surging when i use the block heater , probably cause it is already warm,
, i will have a look at the injection pump when i get back home.
Do you recall the cost it was to repair?
thanks!!
Old Dec 29, 2003 | 07:54 PM
Dave Sponaugle
You will need to go to a shop that works on injection pumps. The shaft is inside the pump in the governor part of the pump. It was a friend of mine that had it done to his truck. I will try to see him and ask but I usually do not see him till the weekend.
Old Dec 29, 2003 | 10:16 PM
fordiesel69's Avatar
fordiesel69
Try installing a return line kit. It comes with new orings and tees. Sounds like an air in fuel problem.
Old Dec 30, 2003 | 08:07 PM
FSC's Avatar
FSC
I would agree with fordiesel69, air in the fuel system.
It took me a while before I 'got it' and it pretty near drove me crazy, it's not fuel leaking out but air leaking in and allowing the fuel in the filter to siphon back to the tank.
Thank god for clear fuel line,
I'm really not as stupid as I feel, really.
Old Dec 30, 2003 | 09:02 PM
Spectramac's Avatar
Spectramac
I'm with Dave on this one, sounds more like a wild governor in the pump than air in the fuel.
Old Dec 30, 2003 | 11:51 PM
mdg97222's Avatar
mdg97222
wow you guys are great! at least i have someplase to look now,
my fuel lines arnt clear tho, im afraid if i take the fuel line off it wont remain tight anymore but well see
Old Jan 1, 2004 | 12:58 AM
Dave Sponaugle
Not only that but if you disturb it much at all you will wind up replacing all the o rings on the return hoods as well as all the return lines between injectors. After a bunch of miles with hot fuel through them they do not like being disturbed.
If it were air, the problem would not go away when the engine was up to temp.
Old Jan 1, 2004 | 01:19 PM
mdg97222's Avatar
mdg97222
oo ok yea i dont need anymore work to do on this truck,
like openning a can of worms (i mean fuel injector lines)
Old Jan 1, 2004 | 01:45 PM
Dave Sponaugle
Smart man, I know because, I been there did that. And I learned a good lesson in the process.
Why is the amount a person learns directly proportional to the dollars/time/aggravation it costs to fix whatever the lesson was about?
Old Jan 1, 2004 | 02:21 PM
mdg97222's Avatar
mdg97222
in my case it because i wana get the most education for my money hehe, i do this with all my vehicles, im all about pinching a penny till lincoln blusehes, but any way its snowing good here and i can play in it,
Old Jan 1, 2004 | 10:25 PM
Dave Sponaugle
mdg where are you? I'll bring my blade and play too
Old Jan 2, 2004 | 12:42 PM
mdg97222's Avatar
mdg97222
o yea heh sounds good im in portland oregon and there lotsa snow for now )
