manual tranny
Old Dec 26, 2003 | 08:52 PM
mcl44's Avatar
mcl44
Question manual tranny
I have a 93 ford xlt inline 6 (4.9ltr) with a 5 speed overdrive transmission (ZF S5-42) (Mazda-R2). The rear of the tranny is leaking. Any thing special to look for? Is the speedometer drive gear a possibility? Is it possible for an avg. mechanic to repair the rear gasket or seals? The truck has 146,000 miles on it.
Old Dec 27, 2003 | 02:25 AM
steell's Avatar
steell
If you have the Mazda 5 speed trans, then it is common for the three plugs on the back of the top to dry out and leak.
Try a search for M5OD and I'm sure you will run across the answer.
