ringing carburetor
Old Dec 26, 2003 | 06:37 PM
davef's Avatar
davef
ringing carburetor
Help... I put a remanufactured carburetor in my 1979 f250, 3/4 ton 4wd , 400. it now has a constant ringing at idle speed. it goes away when i accelerate but returns at idle speed.
Old Dec 26, 2003 | 09:24 PM
Torque1st's Avatar
Torque1st
Posting Legend
moved to proper forum.
Old Dec 29, 2003 | 02:26 PM
CCotten's Avatar
CCotten
I could be a vacuum leak. When you accelerate the vacuum decreases and at idle the vacuum is high. You may have a connection that was not replaced when the carb was changed.
Old Dec 29, 2003 | 07:11 PM
rainbowATF's Avatar
rainbowATF
ringing carb
I had a ringing carb recently. The choke thermostatic spring on the cover was not engaging the choke lever fork in the housing. The vibrating choke butterfly & mechanism was bouncing against the thermostatic spring and causing it to ring. The way it was installed it closed choke when cold but didn't open like it should.
1986F150six
Nov 1, 2016 01:48 PM
52 USCG Panel
22
Mar 31, 2016 03:50 PM
LGx
19
Aug 4, 2013 03:28 PM
LARIAT 85
Jun 10, 2012 06:40 AM
96expblk
Aug 28, 2006 06:10 AM
