Door Adjustment
Old Dec 26, 2003 | 03:09 PM
whweeks's Avatar
whweeks
Exclamation Door Adjustment
I have '92 F-150 standard cab flare side. The door on the passenger side has recently started to rattle and sound like it is not closed all the way, even though it is. How do I adjust it.
Wayne
Old Dec 26, 2003 | 05:15 PM
acerockola77's Avatar
acerockola77
Is the door it's self rattleing or is it the pannel that's loose?
Old Dec 26, 2003 | 06:01 PM
whweeks's Avatar
whweeks
It is the actual door. It closes but you can pull on it and it moves in and out a little.
Old Dec 26, 2003 | 07:15 PM
Saurian's Avatar
Saurian
Our Suburban does that with the drivers door. You close it, and it will have an inch and a half or so of travel, but it locks and everything. We just have to slam it really hard (anger management) to stop it. My Taurus does the same if the lock stuff gets messed with (people putting fingers where the lock and closing mechanism is). Try pulling on the door handle and then lifting anything that looks like it will move upwards. That's always fixed my door...maybe it will help.
Old Dec 27, 2003 | 11:15 AM
2Wise4aGM's Avatar
2Wise4aGM
You can adjust the striker bolt, by loosening it and moving it in. It takes a torx socket and they can be TIGHT sometimes. Also make sure your plastic bushing around the striker bolt isn't worn out or missing.
Old Dec 28, 2003 | 05:57 PM
Superdave's Avatar
Superdave
whweeks
Is the plastic sleeve on the striker bolt missing or broken?
If so, this can cause the exact symptoms you mention.
DvlRacer
Apr 6, 2015 06:31 PM
dreamd0g
Dec 24, 2010 07:59 AM
No-Tyme
1983 - 2012 Ranger & B-Series
Nov 7, 2010 06:00 PM
nsjoblom
Sep 9, 2009 05:58 PM
Larry NCKS
Mar 16, 2009 01:32 PM
