1978 - 1996 Big Bronco
Speedometer
Old Dec 26, 2003 | 12:47 AM
90ebbronc's Avatar
90ebbronc
Question Speedometer
Hey yall my speedo broke today. Actually it has been making a loud noise under the dash and i didnt know what it was, well today it was jumping around (about 10 mph one way or the other) and the noise has eased up alot. So i know its going to break soon, so my question is ...... How hard is it for someone that is not a mechanic to replace, and how expensive is it to do so as well.
Thanks
Old Dec 26, 2003 | 08:25 AM
Howdy's Avatar
Howdy
If you have a 1990, it shouldn't be too hard to find one at a wrecking yard, out of another Bronco or F series.
Old Dec 26, 2003 | 09:57 AM
Bronco86's Avatar
Bronco86
mine has been doing the same thing lately jumping around (going 10mph and it is bouncing between 5-25mph.
Old Dec 26, 2003 | 04:03 PM
steell's Avatar
steell
Generally, when the speedo starts jumping around, it means the cable is dry (or getting ready to break).
Steve
Old Dec 26, 2003 | 08:42 PM
90ebbronc's Avatar
90ebbronc
So how do i grease the cable? If the cable was dry, would it also be making a noise in the dash?
Old Dec 26, 2003 | 10:59 PM
steell's Avatar
steell
It usually does
I forget if the cable comes out from the top or bottom (bottom I think), disconnect the speedo cable housing at the trans, pull the cable out and wipe it down with a rag soaked in light weight oil (trans fluid will work).
Or, you can get some stuff in a squeeze tube from a parts store, and take the gauge cluster out and squirt some lube in from the top.
Taking the cable out is the best way, cause then you can inspect it to see if it's fraying or damaged (and replace it).
Steve
miked79928
Apr 17, 2020 10:22 PM
IJRoorda
Jan 24, 2014 09:30 AM
Still Smoking
2004 - 2008 F150
Nov 10, 2012 03:07 AM
SLAMMIN 22
Jul 30, 2011 04:09 PM
lostin90s
Pennsylvania Chapter
Aug 3, 2007 05:25 PM
