oil filter cap socket
Old Dec 25, 2003 | 11:49 AM
glk's Avatar
glk
where can I find a socket to torgue the oil filter cap on my 6.0 to spec. I think the torque is 18 ft/lbs.
Old Dec 25, 2003 | 11:57 AM
ninelives 59's Avatar
ninelives 59
snap on tools or sears..36mm
Old Dec 25, 2003 | 09:21 PM
ultraclassic's Avatar
ultraclassic
Just use a big-*** cresent wrench and german torque spec of "guten tight"
Old Dec 26, 2003 | 03:56 AM
Tinkertom's Avatar
Tinkertom
GLK
I picked up a 1/2 in. drive metric socket set (sockets only) at Walmart for $10.00 and the largest size was 36mm. Not Snap On quality but great for this application!
Tom
Old Dec 26, 2003 | 04:05 AM
Tinkertom's Avatar
Tinkertom
Oil Filter
Oooops, I should have mentioned also that I was just at Auto Zone online and they list an STP oil filter part#S9549 for $10.00 for the 6.0L. The O ring must be on its' way but not there yet- has manufacturer but says not yet available
Old Dec 26, 2003 | 10:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Re: oil filter cap socket
If it is .............
18ft/lbs can be achieved by with an 8' crescent, not very much at all!
Old Dec 26, 2003 | 02:48 PM
PowerStroke6L's Avatar
PowerStroke6L
Just get a GM 36mm axle nut 1/2" drive socket. I purchased one for about $8.
Old Dec 26, 2003 | 04:47 PM
IB Tim's Avatar
IB Tim
Do we know for sure that it is 18lbs
Old Dec 26, 2003 | 05:13 PM
emtabmm's Avatar
emtabmm
Oil drain pan plug 18 ft/lb
Oil filter is 12 ft/lb
Old Dec 26, 2003 | 05:18 PM
IB Tim's Avatar
IB Tim
You so good..................
And that means you don't need a 18" cheater bar to accomplish the TQ
Old Dec 26, 2003 | 09:07 PM
swifturtle's Avatar
swifturtle
All,
I was lucky enought o get my hands on the International service procedure and systems description manual. According to the manual the torque specs are as follows:
Oil Filter Cap 18 lbf/ft (24N.m)
Oil pan drain plug 18 lbf/ft (25N.m)
Not sure why the difference on the metric torque spec. But hope this helps.
Old Dec 27, 2003 | 11:11 AM
glk's Avatar
glk
where can i go to fid the torquesw written down they are not in the owner's manual from ford to look at them for my self.
brandon.edwards
Aug 2, 2013 04:39 PM
Fandini
May 28, 2011 02:42 PM
lechonera
Sep 28, 2010 01:19 PM
wiingnut
Nov 15, 2004 01:54 PM
chandlerbf
Jul 31, 2004 11:30 AM
