Moisture Problem
Old Jan 19, 2004 | 08:53 PM
mcb45's Avatar
mcb45
Well, got the truck back and so far it looks like after all this time and money it was simply a plug with small fractures in it, much like my buddy here above. Hopefully this solves all the problems. I am going to wash it in the morning and see if it dies, let's hope...
Old Jan 20, 2004 | 06:20 AM
LxMan1's Avatar
LxMan1
Don't get water in the plug pockets. It will short out the COP's and possibly burn them up. @ over $65 a piece, that's over $520 to replace them all!!!
Old Jan 20, 2004 | 11:23 AM
Phil056's Avatar
Phil056
If you need to detail and or clean the motor and you will be getting it wet make, sure that you let the motor sit for a long time before starting to make sure that it is completely dry. The coil packs are the culprit, if they are wet you will eventually get the same scenerio. You don't want the rear coil packs to bust b/c they are a b!@ch to get to and to get out if you don't have the correct tools and or patience.
If you have an air compressor, you might want to short blast some air around the coil packs after washing to remove any standing water in the deep recessed areas where the plug sits.
Good Luck
Old Jan 25, 2004 | 01:39 AM
mcb45's Avatar
mcb45
Well, it seems that the spark plugs were the problem after all. I washed the car and it has been in the rain and no problems. It seems insane after 5 months and much money spent that all along it was the stupid spark plugs. Don't have a whole lot of confidence in the dealership anymore, if I ever had any.
Old Jan 25, 2004 | 02:09 AM
LxMan1's Avatar
LxMan1
Glad to hear that you got it fixed
Humphrey99
Nov 4, 2013 01:03 PM
68bronco79crewcab
Nov 30, 2010 11:27 AM
jergarza1313
3.8 & 4.2L V6
Aug 18, 2010 11:47 PM
Sandman1991
Apr 27, 2008 02:58 PM
highlandescape
Escape & Escape Hybrid
Jan 13, 2007 05:40 PM
