Sponsored by: Real Truck
BackRack Question
Old Dec 24, 2003 | 10:41 PM
fordy88's Avatar
fordy88
BackRack Question
Hi,
Just picked up my 2004 F250 SuperCab with bedliner and no toolbox and 6.75' bed. Occaisionally I transport a short (22') extension ladder - it measures about 12' collapsed and I was wondering about using a BACKRACK. I was hoping someone has experience with it.
Specifically how high above the roof do the vertical posts extend? I only have about 2" of clearence going into my garage. And is the Tailgate Bar necessary or recommended in transporting ladders? Also, does the Tailgate Bar come off easily because I need to access the bed with no obstructions when I'm not carrying my ladder.
Are there other systems I should be looking at? It's only for infrequent usage so I was not interested in a rail mounted track system. Thanks in advance for any suggestions. Happy Holiday's to all!
Old Dec 25, 2003 | 06:40 AM
klp's Avatar
klp
Hey Fordy, I have the exact rack that you want on my 99 250. It extends about 2 inches above the roof, I could go out and measure later of you want. My truck is a 2wd and I can fit in 6'8" garages. Barely. I have never actually measured the height though.
For what you are doing I am not sure you need the back piece. It helps to really secure stuff but if you only carry ladders once in a while you could simply strap it real good to the top rack. The back piece comes off real easy, it simply slips into those holes on the back of your bedrail. Hope this helps. KP
Old Dec 25, 2003 | 06:50 AM
fordy88's Avatar
fordy88
Thanks for the help. It would be great if you could measure the vertical height of the Rack itself - from the bedrail to the top of the highest point of the vertical posts. Then, I'll just drive my truck under the gararge door opening and measure up to see if there's enough clearance. I understand from their web site that the BackRack bolts into the stake pockets but does the tailgate bar bolt in as well or simply drop in. Thanks again.
