Really cool F250
New style F150 version.
Full floating 7 lug rear axle.
SLA front end with torsion bar suspension.(2wd or 4x4)
4 leaf rear susp over solid axle
10" rear differential.
5.4L 3valve v8 engine as standard.
4.9L I6 DIESEL optional. (3,600.00)
NV4500 HD 5speed manual transmission/w creeper as standard
Auto tranny optional with both motors.
New baby Torque shift also optional with diesel.
GVWR 8600Lbs GCWR 16000Lbs
Reg cab 2wd Max Payload; 3500lbs
Reg cab 2wd Max Towing; 10,500lbs(diesel) 9200lbs(gas)
Fixes; Fix the park bench stiffness of the seats.
This would be the new F250 (no LD or SD-just F250 3/4 ton)
Stop producing the 250SD, and give all SRW SD's the F350 designation and 9900Lb GVWR.( almost the same truck now anyway-ever hear of Fords magic dust? Somehow without changing anything but the tires on the F-350SRW and adding a 2" spacer between the rear axle and the spring pack-the truck gets a HUGE payload upgrade)
I for one think that this would address the needs and wants of alot of F150 buyers and SD buyers at the same time-it would certainly bridge the huge gap between the two models so as to better address some peoples needs.
Plus it would allow those who want a manual transmission with the new body style to get their fix, the NV4500 is also a much heavier duty trans than the M5od could ever hope to be anyway.
What do you think guys? Would any of you consider buying this truck?
And yes that would suit my needs. "What you described"
