Fuel Pump?
Old Dec 24, 2003 | 11:04 AM
rmarion's Avatar
rmarion
Fuel Pump?
I have a 97 Ford Ranger (Sons). Last night his truck would not start. He was low on fuel, added 5 gal, still would not start. It cranks over good, I do not hear the fuel pump working when it is turned on, I just hear a click. It will start when I add gas to the carb, but won't stay running.
Any ideas?
Thanks
Old Dec 24, 2003 | 11:19 AM
LxMan1's Avatar
LxMan1
Check the safety shut off relay which is located (usually) around the passenger side kick panel. It may have gotten bumped and kicked out.
Jimmy
Old Dec 24, 2003 | 11:59 AM
rmarion's Avatar
rmarion
These items have been checked and are working..
1. fuel pump saftey shutoff switch is ok
2. fuel pump relay fuse relay is ok
3. PCM power fuse relay is ok
4. Power Point ? 30amp fuse blown, now replaced.
Old Dec 24, 2003 | 12:16 PM
rmarion's Avatar
rmarion
Jimmy
Jimmy
Thanks, that was it.
