Sponsored by: Real Truck
sloppy steering
Old Nov 7, 2002 | 05:24 PM
dye60's Avatar
dye60
sloppy steering
I am trying to figure out what folks do to make the steering stiffer. I have about a 1/4 play and have replaced the tie rods. What else can I do?
Country Cowboy w/
F350 4X4 powerstroke 7.3L 35" Crewcab Longbed
Old Nov 8, 2002 | 08:13 AM
79CEEJAY's Avatar
79CEEJAY
sloppy steering
I had sloppy steering on mine too! It has around 6000 miles on it now and the steering got progressively sloppier. Took it back to the dealer and told them. They adjusted the steering gear and it is fine now. How old is your truck? Is the front end tight? ie:ball joints, linkages, etc. I don't know how old your truck is, but if it is new (under waranty) I would have the dealer check it out. The steering box adjustment worked for me! As a matter of fact, for the first week, I found myself oversteering on the highway because I was used to the play in the wheel, but now it is great!
Old Nov 8, 2002 | 09:51 AM
dye60's Avatar
dye60
sloppy steering
The truck is a 97 and all the joints seem to be OK but the tie rod moves/twist when turning. Do you think a steering stablizer would help?
Country Cowboy w/
97 F350 4X4 powerstroke 7.3L 35" Crewcab Longbed 35's
Old Nov 8, 2002 | 09:57 AM
Yeti's Avatar
Yeti
sloppy steering
They ususlly turn about 1/4 inch, which is normal, most likley you box is warn abit and can be adjusted.
NO You would only be masking the problem.
Old Nov 8, 2002 | 10:27 AM
dye60's Avatar
dye60
sloppy steering
Not 1/4" but 1/4 turn of the steering wheel.
Country Cowboy w/
97' F350 4X4 powerstroke 7.3L 35" Crewcab Longbed w/35"
Old Nov 8, 2002 | 10:38 AM
warmdye's Avatar
warmdye
sloppy steering
nice to see another dye
Old Nov 8, 2002 | 11:59 AM
rollnxl's Avatar
rollnxl
sloppy steering
