1999 - 2000 idm location?
Old Dec 23, 2003 | 08:13 PM
bigblock427's Avatar
bigblock427
help i cant find the injector drive module in my f550 is it hidden under something?
Old Dec 24, 2003 | 08:35 PM
bigblock427
maybe its not in there?
Old Dec 24, 2003 | 08:42 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's there. Pull the inner liner out of the driver side wheelwell, you'll see it.
Old Dec 28, 2003 | 07:18 PM
bigblock427
is it under the air filter box or do i have to pull the wheel well out under the fender thanks keith
Old Dec 28, 2003 | 08:46 PM
cookie88's Avatar
cookie88
FTE Emeritus
Jack up the front, pull the drivers side wheel off, drop the wheel well liner down. The IDM is bolted to the inner fender behind the liner.
Old Dec 29, 2003 | 11:13 AM
brabe's Avatar
brabe
Is the idm located in the same place for a 95 psd. My truck has been acting a sluggish and several times it has died while driving. I replaced the cps. When it dies i let it sit a while and crank the motor for about 20 seconds and it finally starts. it act like it ran out of fuel. The ford truck tech said it was the idm. does this sound right? they want $900 for parts and $380 to install. is't the idm fairly simple to replace??
thanks
Old Dec 29, 2003 | 01:58 PM
cookie88's Avatar
cookie88
FTE Emeritus
I think it's in the same place on the earlier ones. Might as well save the labor costs.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
