Door panel removal
Old Dec 23, 2003 | 05:50 PM
glgreer's Avatar
glgreer
Door panel removal
I own a 1999 Eddie Bauer Expedition, can anyone tell me how to remove the rear door panel.
thanks!!
Old Dec 23, 2003 | 11:34 PM
gkbid's Avatar
gkbid
Don't know if this will help - it's for the front panels - might try a search @ top for more info.
https://www.ford-trucks.com/framered...yfrontdoor.jpg
Good Luck
Old Dec 24, 2003 | 07:05 AM
BigMan69's Avatar
BigMan69
Re: Door panel removal
thanks!!
1. Carefully pry out door release handle trim starting at edge closest to speaker grill. Rotate the trim to expose 5/16" bolt in door release handle. Remove bolt and handle.
2. Carefully pry up each end of power window switch panel, disconnect switches and remove panel.
3. Remove 2 phillips screws from bottom edge of door panel.
4. Slide door panel upward to release and remove panel
BigMan69
