1978 - 1996 Big Bronco
intermittant knock.
Old Dec 23, 2003 | 04:41 PM
adanacro's Avatar
adanacro
intermittant knock.
Sounds like it's in the valve train and it comes and goes,usually worse at higher rpm's.
At idle even, when I can hear it clearly under acceleration ,it goes away.
It seems to knock at very odd times,like sometimes cold in the morning and sometimes after having driven around for a while.
Oil level is good but I'm not too sure about the oil pressure as the gauger is untrustworthy.
It's an 88 351.
Any help would be appreciated
I tried to search.
Old Dec 24, 2003 | 08:08 AM
BOJOFASO's Avatar
BOJOFASO
years ago i had a bad wrist pin bushing and it sounds just as you describe. it sounded like valve train and rerally had me fooled. seems that when the cylender fired id get a loud knock. it would come and go as you describe.
Old Dec 27, 2003 | 07:14 PM
adanacro's Avatar
adanacro
I've considered wrist pin but keep coming back to it not knocking all the time.
I guess at the very least next time it's knocking loudly I'll pull over and try to isolate which cylinder it may be.
Old Dec 27, 2003 | 09:04 PM
tHeCoS's Avatar
tHeCoS
Sounds like my problem...after 10 to 20 mins of driving, at Idle with DRIVE and/or PARK, I get that knocking. But not along with RPM. I've located the knock somewhere in the bottom end through oil pan.
Also the oil pressure gauge wigs out , after awhile of idle... the pressure will goto and stay at (L) but idle is still there.
I've read some threads about the oil pressure wigging out. But not my knocking noise.
Old Dec 28, 2003 | 04:07 PM
BOJOFASO's Avatar
BOJOFASO
i thought the same as you on the wrist pin. but as the bushing spins in the pin guide this would cause the knock to come and go. i drove mine to lake george towing a boat and had no problem but i was just lucky and would not suggest driving that far. but again it really had me fooled .
Old Dec 29, 2003 | 11:37 AM
tHeCoS's Avatar
tHeCoS
Where is the wrist pin bushings? that's the first I've heard about it.
Old Dec 29, 2003 | 07:31 PM
BOJOFASO's Avatar
BOJOFASO
they are bronze type bushing that lines the two holes in the piston where the wrist pin goes through.
Old Dec 31, 2003 | 08:17 AM
steell's Avatar
steell
IIRC, the 302 and 351 use pressed in piston pins. That means the pin is pressed into the rod, and the piston rotates around the pin. There are no brass bushings involved on pressed in pins.
On a full floating pin (aftermarket rods) the rod has a brass bushing it it, the pin is held in place by clips on each end, and the pin is free to rotate.
Steve
