studdering 91 explorer
Old Dec 23, 2003 | 02:48 PM
rustbucket64f100's Avatar
rustbucket64f100
If anyone can help would be great, i have a 91 explorer and at highway speeds usually around 65 or so, if i start to go up a hill or accelerate it starts to studder or miss a little bit. if i push it to the floor, it goes just fine. Anyone have any ideas?
Old Dec 23, 2003 | 05:22 PM
emtabmm's Avatar
emtabmm
plugs and/or wires....?
Old Dec 23, 2003 | 06:15 PM
rustbucket64f100
I just changed them 3 weeks ago when i bought the explorer.
Old Dec 23, 2003 | 08:25 PM
mike312's Avatar
mike312
check your fuel filter,have you ever ran close to empty?personally it sound like wires and or plugs or a faulty ignition,kinda like something is getting ready to go!
Old Dec 23, 2003 | 09:13 PM
greenexplorer's Avatar
greenexplorer
I've been having a similiar problem. can't seem to figure it out. if you get it could you please let us know what the fix is? thanks and good luck!
here is a link to my thread --
Old Dec 24, 2003 | 01:25 PM
mrshorty's Avatar
mrshorty
I could see a dirty MAF doing that to you. A bad O2 sensor (O2 sensor data i ignored at WOT). A bad TPS (PCM doesn't always know where the throttle is at.
1st thing I would do is perform EEC-IV self tests to see if computer can see a fault. Also check fuel pressure/delivery and make sure the engine is getting fuel.
Old Dec 25, 2003 | 10:54 AM
rustbucket64f100
How do you check the MAF sensor?
Old Dec 25, 2003 | 03:22 PM
marragtop's Avatar
marragtop
Have you pulled diag codes on it yet? If so, what were they?
Old Dec 26, 2003 | 01:23 AM
jclj2003's Avatar
jclj2003
maybe u joint hey just a guess but my expoder did mostly like that and did the u joints and no problems now
Old Dec 27, 2003 | 03:09 PM
mrshorty's Avatar
mrshorty
Couple of things to do.
First, because the MAF often causes problems becasue the filaments are dirty, which won't show up while testing the sensor electronics, I would open it up and check/clean the filaments. Use a Q-tip and a volatile solvent (I use isopropyl alcohol) and gently wipe the crud (if any) off the filaments.
As for verifying the sensor electronically, I don't remember the specifics, but a good manual (may need a professional strength edition. not sure Haynes/Chilton's will have a good description. Check the library) will have specifics. You'll use a volt meter to check the supply voltage to the sensor and the output voltage.
