speedometer calibration
Old Dec 23, 2003 | 02:46 PM
78fordman's Avatar
78fordman
I purcahsed my 78 F-100, about a month ago, and i had someone follow me and flash their lights when i hit 55. My speedometer said 42 when i was going 55. I have a 18 tooth speedometer gear. What size should my new gear be?
Old Dec 23, 2003 | 02:59 PM
StrangeRanger's Avatar
StrangeRanger
To make the speedo read higher, you need the cable to be spinning faster. That requires a smaller driven gear.
If their speedo was right, and it may not be, you'd need a gear:
18T x (42/55) = 13.75
That would be a 14T gear which AFAIK doesn't exist, The smallest available is 16.
Old Dec 23, 2003 | 03:01 PM
78fordman's Avatar
78fordman
Sounds like i need some lower rear gears
Old Dec 23, 2003 | 03:08 PM
78fordman's Avatar
78fordman
how hard is it to change the drive gear? If i got a larger drive gear, i could make it work.
Old Dec 23, 2003 | 05:22 PM
StrangeRanger
Pull the tailshaft housing, remove the old gear, slide on a new, replace the seal while you're at it and reassemble. There's probably a snap ring or something, I've never been inside a T-18 but they are reputed to be very simple to work on.
Old Dec 24, 2003 | 11:36 AM
78fordman's Avatar
78fordman
what size is the stock drive gear? it is for a NP 435, the driven gear needed is a 14, so what gears will i need after the drive gear change?
Old Dec 24, 2003 | 12:57 PM
StrangeRanger
Driven Gear tooth count = (Tire revs per mile x rear axle ratio x drive gear tooth count)/ 1000
