View Poll Results: Satisfaction survey
Have you had any problems with your 6.0PSD?
40.74%
Have you had any reflashes?
14.81%
Has your performance improved after reflashes?
7.41%
what is your average MPG?
14.81%
What is your overall rating of your truck?
22.22%
Voters: 27. You may not vote on this poll
6.0PSD poll
Old Dec 26, 2003 | 12:57 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally posted by Nevada
Nothing yet at 1300 miles. Well nothing except my irresistable urge to stomp on the pedal.
My urge has gone form irresistible, to just plain "do it" This usually comes around 2/3k miles on the truck.
You will get there soon enough, be glad you are not afflicted with the “WOT all the time problem” no cure for it, Ford has no answers!
Old Dec 26, 2003 | 01:13 PM
emtabmm's Avatar
emtabmm
I think that has something to do with poor mpg also Tim.....
Old Dec 26, 2003 | 01:29 PM
IB Tim's Avatar
IB Tim
O-yea, if my foot is not resting on the floor, it is 21.2 MPG
But you have got to know that all these guys and gals know this. If I run mine........like.......well you know..........hard, it gets 14.9/17.1
Disclaimer:
Mileages may vary depending on openness of roads in your area, and style of driving on the interstate, i.e. cruse control, or T/H or not, all those things.
Old Dec 26, 2003 | 02:15 PM
cravenc's Avatar
cravenc
Jeepgod,
I have experianced water on the driver side floor board aswell. This happened a couple of times and went away. I dont know if the AC drain line got stopped up and made it back up in the cab or what. Please let me know what the out come is on yours...............
Old Dec 26, 2003 | 03:35 PM
jeb's Avatar
jeb
03 Excursion, 5/03 build date, bought 9/3/03, 6500 miles
1. Have you had any problems with your 6.0PSD
-Yes. Bad turbo actuator, leaky front crankshaft seal, smokey starts, occasional rough running.
-Yes, two.
-Not that I can notice.
About 16mpg.
-I like the truck overall. Maybe a B-. I think you're asking more about the motor, though. I'd rate that a D+. It's disappointing. And I figure I have one of the good ones.
Old Dec 26, 2003 | 04:00 PM
emtabmm's Avatar
emtabmm
JEB, have you had the dec. 12 flash?
Old Dec 26, 2003 | 08:19 PM
ed kapala's Avatar
ed kapala
Our Company owns 12 F350 6 Litre trucks at this point and have owned as many as 16. We have had nothing but trouble with these trucks. Almost all being engine problems. As of Dec. 24 we had 7 of the 12 into differerent dealerships around the province for repairs, the most serious being a blown engine. That is the third repair in 6 weeks for that particular truck. We have a tremendous amount of diesel and mechanical background and although these are oilfield trucks they are not worked hard as all they carry is a constant static load of 800 pounds.We sold the first two we bought as they were in for repair more than we had them. It seems that about 6500 miles of relatively trouble free driving is all we can expect before more problems crop up. Here is a list of the problems we have encountered: Bad or no cold weather start, poor or rough idle, no power, will stop running altogether (computer reflashes have helped but I think Ford is on number 14 now), EGR Valves, ICP Sensors, wiring harness problems, fuel gelling problems, injector problems (with both the old and new injectors), no shift , no start, blown turbos when the injectors go bad, charge air cleaners obviously, and blown engines. We have a total of approximately 200,000 miles of experience with these trucks and we can't afford another mile. As soon as we can find buyers in the Spring when our work slows down we must look at a better vehicle. As far as we are concerned this is the worst diesel engine introduction we have ever seen and long for our old fleet of Cummins engines. If you haven't had problems, you will, trust me. We know that we will never trust Ford again.
Old Dec 26, 2003 | 08:29 PM
IB Tim's Avatar
IB Tim
OUCH, that will leave a mark
6500 miles is when things started going bad?
Old Dec 26, 2003 | 08:35 PM
Nevada's Avatar
Nevada
To ed kapala - do you have the year of the trucks, or better the manufacture dates?
Old Dec 27, 2003 | 08:46 AM
ed kapala's Avatar
ed kapala
The year of the trucks is 2003 with the manufacturers dates ranging from January 03 to July or August. The first problems started showing up almost immediately on the early production models. These trucks ended up on flat deck trucks as much as being driven.
Old Dec 27, 2003 | 08:53 AM
IB Tim's Avatar
IB Tim
Check out
https://www.ford-trucks.com/forums/s...hreadid=185570
Please read completely:
Old Dec 27, 2003 | 09:26 AM
tater salad's Avatar
tater salad
Have you had any problems with your 6.0PSD? Have you had any reflashes? Has your performance improved after reflashes? what is your average MPG? What is your overall rating of your truck?(1) Yes, the ipc and pcm replaced.(2)Yes(3)yes seems stronger.(4)14-18 (5)on a 1-10 scale a 6
Old Dec 27, 2003 | 11:28 AM
  #28
AAFD's Avatar
AAFD
No problems with my new truck!
No flashes as of yet.
Mileage is about 18 average with 21 best!
KC
Old Dec 27, 2003 | 11:31 AM
  #29
IB Tim's Avatar
IB Tim
KC
Try this one
Check out
There is some problems linking the thread,
If you have problems go to the 6.0 area and click on
Problem/mileage on 6.0’s to all owners!
Old Dec 27, 2003 | 12:50 PM
  #30
IB Tim's Avatar
IB Tim
NOW IT WORKS
or try this link one more time!
www.ford-trucks.com/forums/showthread.php?s=&threadid=185570
