About 2 years ago I inherited a 1966 F-100 and although I have become very good on the mechanical end my diagnostics skills are not good at all so I would appreciate some help. 2 days ago I was driving down the road and all of a sudden the truck cut out on me and let out a massive backfire so I rolled to the side of the road and when I tried to restart the truck all it would do is backfire every now and again. I put a new 1976 351w inside shortly after I received the truck and it has ran great ever since until now. Any help would be appreciated.
Sounds like the timing check to see if the rotor is turning if it is not it could be the gear pin is sheared then it also could be the timing chain . One other thing that comes to mind is the fuel pump i have had alot of fuel pumps go bad on my 351ws i just got a holley works great.
Don't think I'm stupid but did you check the points? Same happened on mine and I put a resistor in line to the hot side of points. That stopped the burned up points all the time. Still keep a fresh set in the glove box.
