Skyjacker 2" axel pivot brackets
What kind of truck? On my F-150, when I had the TTB, I had a set of the center drop brackets. The directions that I had said to drill out the rivets on the stock brackets and replace with the new brackets and grade 8 bolts. I don't see why you would need to weld the new brackets on if they fit in the stock locations.
Again, I wouldn't think they should be welded to the crossmember, but every manufacturer is different. Take a look to make sure that they mount up like the stock brackets. You should be able to utilize the existing holes, and may actually have to drill a few new ones in either the bracket or the crossmember for support. Then bolt it all together using grade 8 stuff, should be just fine.
CHUCKS65PHUGLY
06-23-2006 09:06 PM
abelmoreno
06-23-2005 10:57 PM
sandman3510
07-22-2004 03:36 PM
rustyolred27
09-16-2003 09:18 PM
