Gauge problems
Old Dec 21, 2003 | 08:42 PM
F 2fifter with a 4 sixter's Avatar
Question any of you 80to86 F series owners have gauge problems
Hi i am having gauge troubles with my truck they are really starting to bother me they dont read correctly at al do any of you have these problems to low oil presuure temp and gas gauge readings? if so is there a way to fix them are there aftermarket gauges avaliable that would cure the problem?
EDIT :my truck is a 1984 F250 with a 460 XLT
Old Dec 21, 2003 | 09:25 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
i installed a mechanical oil pressure gauge in my 83 f100. the stock one just sucked. my gas gauge on my back tank is 1/4 tank off towards full. so when im on 1/4 tank im really on empty. but my front tank gauge worked until the tank rusted through and i took it off. i need a mechanical temp gauge but ran out of room to mount it. my oil pressure gauge is under the dash to the left of the ashtray. theres a constant voltage regulator behind the instrument cluster that supplies 5 volts to the gauge sensor. you might try changing that and the fuel tank sending unit. that would probably fix the gas gauge. then buy a guage set for the oil pressure and temp. you can buy a gauge pod for the a pillar so you can mount gauges there. i need one for my truck. they sell em in jc whitney.
Old Dec 21, 2003 | 11:33 PM
kermmydog's Avatar
kermmydog
Ford has always said if the gauges read in the normal all is well. My Mustang GT read goffy. I did as th person above put mechanical oil & water gauges in my 86 F250.
Old Dec 22, 2003 | 02:08 PM
TowinBob's Avatar
TowinBob
Your truck has an "instrument cluster voltage regulator" on the back of the cluster. It is about an inch and a quarter long by half inch square. It has a mounting tab and plugs in to the cluster with terminals like on a 9 volt battery. When they go bad the gauges will act really weird. Hope this helps.
Bob
Old Dec 23, 2003 | 05:24 AM
Yes i got a new from Napa and they didnt help so i went to junk yard today and got a hand full from vans trucks and broncos to experiment and the right awya the first one i put in made a diffrent along with some other guages out of a bronco that has the cool factory tach set up that i also installed in my truck but it dfidnt stay working long i took it apart looked at it everyhting was ok fromw aht i could see i put it back it worked a little then quit on me again meseed with the wiring to it worked againt hen quit again so i just took it out but at least i know what my truck tachs at at 65 at its 3000RPM which isnt to bad
DR Smith
24
Jun 13, 2014 03:36 PM
gjwniflst
Jul 16, 2013 08:13 PM
gjwniflst
20
Jun 24, 2013 07:06 PM
Senor del Taco
Nov 17, 2011 08:11 PM
jacked & black fx4
2004 - 2008 F150
Jun 17, 2010 12:21 PM
