temp gauge problem
Old Jun 11, 2013 | 09:32 PM
gjwniflst's Avatar
gjwniflst
temp gauge problem
I have a 1960 F100 that someone transplanted with a 1957 312 Yblock. The truck has an aftermarket gauge set and the standard dash gauges/idiot lights.
My problem is in the temp gauges. The aftermarket gauge reads a safe temp + - 180. The location of the sensor for the aftermarket is near the #8 cylinder intake. The dash gauge pegs the hot line in about 10 to 15 minutes of drive time. That sensor is located on driver side block just above oil sending unit.
I have used an infrared temp probe (laser) and get basically the same readings as the gauges, respectively.
Could I be reading oil temp on the dash guage or do I have a water flow restriction in the lower part of the motor?
Old Jun 11, 2013 | 10:50 PM
Osubuki's Avatar
Osubuki
I would verify that the sending unit to the stock gauge is matched to the gauge. Had a similar issue where a modern sending unit was sending a false read to the gauge. The infrared was telling me otherwise. Once I got the correct sending unit for older gauges everything checked out.
Old Jun 11, 2013 | 11:52 PM
gjwniflst's Avatar
gjwniflst
Never thought about having to match gauge to sending unit. How do I find the correct sending unit for my gauge? Who do I ask?
Old Jun 12, 2013 | 08:42 AM
The Horvaths's Avatar
The Horvaths
I think you're saying that both the infrared and old sensor/gauge tell you that one head/side of block (left?) is hot. Best figure out why. If you trust that the new sensor/gauge are reasonably accurate, which is a fair assumption, then you may temporarily move it to the suspect hole and triple-check its temperature. I would figure it out for sure prior to running it much more.
My 2c
Old Jun 16, 2013 | 10:21 PM
gjwniflst's Avatar
gjwniflst
temp problem
My 2c
Short of splicing wires, I tried changing sensor positions but the thread hole sizes are different and the shaft for the intake sensor is to long to go in the hole for the block position. I could do a lot of adapter searching and make it work but I think splicing will be faster and easier.
Old Jun 16, 2013 | 10:58 PM
The Horvaths
Splicing would ONLY work if the two gauges (old stock style and newer, aftermarket, yes?) and their respective sending units were mutually compatible. My instinct tells me that this is rather unlikely.
Old Jun 18, 2013 | 10:40 PM
gjwniflst's Avatar
gjwniflst
temp problem
I don't see a problem with splicing. A wrie is a wire. Both sensors are single wire and ground to motor. They send there information to the gauges via resistance. I would believe that I would get the original reading that I had at the dash gauge on the aftermarket gauge and vice versa. Do you see this as potential problem?
Old Jun 19, 2013 | 01:40 AM
The Horvaths
If what you're saying is that it won't burn anything up, then that is possibly correct. However, the old gauges/sending units worked off of a thermal switch mechanism. Their sending units were not a temperature-coefficient-dependent resistance like many, if not most, newer ones are. So, the odds that you'll get a correct reading may be rather slim.
Last edited by The Horvaths; Jun 19, 2013 at 01:41 AM. Reason: Typo - chell specker.
Old Jun 20, 2013 | 05:24 PM
gjwniflst's Avatar
gjwniflst
Maybe I'll just leave it alone and trust the laser and aftermarket gauge.
Old Jun 20, 2013 | 05:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As I recall, somewhere after 56 Ford went back to 6v gauges with the CVR to reduce 12v to 6v. The '60 truck would certainly have a CVR (or should). Maybe the PO got rid of it? If it were missing that would explain the bogus reading.
Y-blocks don't have separate cooling systems for each bank like a flathead V8, do they? There's only one water pump. The lower part of the engine (block) gets water first and runs the coolest.
Stock gauges are not to be trusted even when new. Now they've been mix'd and matched so who knows what you've got? You could buy a new sender for a '60 F-100 and try that, after verifying the CVR is there.
Old Jun 20, 2013 | 07:00 PM
bk53's Avatar
bk53
I can't quite make out what your original post says, one gauge ok the other hot and laser agrees with the gauges respectively? or something. if the laser says it is over hot, it probably is. I'm not sure where best to measure a y block. only just learning my chops on a flatty.
bill
Old Jun 20, 2013 | 07:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by bk53
... I'm not sure where best to measure a y block.
bill
The thermostat housing is the most reliable place.
Old Jun 21, 2013 | 12:01 AM
gjwniflst's Avatar
gjwniflst
temp problem
Thanks for the info, please excuse my ignorance but what do the letters CVR mean?
Old Jun 21, 2013 | 09:51 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Constant Voltage Regulator. Looks like this, mounted under the dash
Old Jun 21, 2013 | 09:12 PM
gjwniflst's Avatar
gjwniflst
If the PO replaced the generator with an alternator would you still need the CVR? Does the CVR also supply voltage to the fuel gauge?
