Which motor do you have? I have gas, so I am going to stick with Motorcraft 5w20 mixed synthetic. If you have a Diesel, I don't know anything about the weight requirements etc. Again though, if you have a 5.4, or a V10, gas motor, I don't think M1 makes a 5w20... do they? As far as MPG, I don't think you are going to get any better than you are running the factory specified 5w20. Just my opinion.
My first oil change, I used Motorcraft 5W20. My second oil change, I used Mobil 1 5W30. Last oil change, I used Mobil 1 0W30. The mileage has been the same with these 3 oils, between 12 mpg and 14 mpg city driving and 18 to 20 mpg highway driving. I changed the oil in the transmission and used Mobil 1 Synthetic ATF and it does shift a lot better now and it whines a little less when cold.
I have used syn for over 20 years and keep good records. I would be very hard pressed to prove that I save gas.
Since syn is claimed to get you single digit percentage gains, you can't expect to see much change especially with a vehicle that gets mid teens on a lucky day. With single digit percentm you will see less than 1 mpg which is easily lost in the noise of many variables that affect mileage on every tank.
But I do use syn for extended temperature range and other claimed benefits.
Check out the oil forum for years of pros and cons on syn versus dino.
I have switched to Amsoil 5W-20. This oil is one of the leaders in synthetic. I hade cold pison slap and cold mornings in my V10, I changed from the motorcraft synblend to the Amsoil. The cold knock was gone and has not come back. The oil is more $$$ but to me it is worth it. Also, the only synthetic oil to state a 7500 mile or 6 month oil change cycle. NO other oil claims this. When you drive 25K a year....laying underneath you truck every month gets old quick.
I totally agree with boxcar1974, I use nothing but Amsoil 5wW-20. I've been using since day one so I can't tell you if it gives you better MPG, but I've had no problems and it is the best oil on the market in my opinion.
Originally posted by 92f150I6 Mobil 1 reccommends their 0W30 for vehicles using 5W20. I'm going to switch when it's time to change my oil.
Actually, that's 0W20 that Mobil1 recommends. I just looked it up. I don't know, seems really thin to me. We are getting into 3in1 oil territory I think.
I can't really comment on the fuel mileage benefits of using synthetics but I can definitely say that it is superior to conventional oils. I use nothing but synthetics in my boat. That engine is put under a heck of a lot more stress than you could ever dream of putting an automobile engine under. I have my BB Chevy motor above 4K almost all the time and sometimes at WOT for 3 minutes or more. Synthetics don't breakdown due to heat as fast as conventional oils. One note of caution. Don’t use synthetics until a motor is thoroughly broke in. The superior lubricating qualities will actually prevent the rings from properly seating.
