Cam distributor problems.
Old Dec 21, 2003 | 02:57 PM
tracman's Avatar
tracman
I have rebuilt my 351w, but am having a serious problem trying to get the Distributor to go in. I have tried two separate cams, and two different distributors.
I dropped the Oil pump, to eliminate any doubt that the Drive shaft was causing a problem.
I have turned the cam and distributor every way possible and the dist. will not go in. It hits the cam solid and will not go into place.
Would you all have any Ideas as to what could be causing the problem? I have never had this problem with any engine. (I've dealt mainly with Mopar engines though)
I would really appreciate any help with this problem.
Old Dec 21, 2003 | 04:09 PM
71swissaqua's Avatar
71swissaqua
Do you have another known good distributor to try? Any chance the one you have is not for a 351W? If the cam is not installed will the dist. go in ok? Strange problem give us more information.
What did the dist. come out of? Is it a new cam?
Clint
Old Dec 21, 2003 | 04:46 PM
c_rossman's Avatar
c_rossman
Maybe the gear is on backwards? or the gear is for a big block which is larger.
Old Dec 21, 2003 | 04:56 PM
tracman's Avatar
tracman
Actually you are right on the second one. Another guy mentioned to me that they may have sold me a 351C dist. So I ran the parts number on Oreilly's website and that is the problem. I've got to go in the morning to order a 351w dist....
I quit working on this truck a couple months ago due to this problem and not enough time. So this truck has been sitting for about 2 months, just because the Idiots didn't see the C at the end of the 351.......
Quite POed and quite happy that the problem has finally been discovered...
Old Dec 21, 2003 | 08:58 PM
ecarter50's Avatar
ecarter50
351c distributor will fit 351w if you change the gear.
Old Dec 25, 2003 | 08:53 PM
tracman's Avatar
tracman
Well, they can't seem to get it figured out that they have their stupid numbers wrong.
So here's my next question.
On this page at Summit Racing They have different Shaft Sizes listed for the 351w. I have a Stock Cam for this truck. So would the last gear listed be the one I need. Iron Dist gear
I know the iron gear would be best, but this one doesn't show a shaft size. So I'm not sure if I need to order it or not....
Thanks for the responses so far.
Old Dec 26, 2003 | 10:39 AM
daerhldgs2's Avatar
daerhldgs2
use care in selecting the gear as you use a different gear steel /cast/bronze depending if you use a roller cam or not i.e. the gear on a dist. for a roller cam will eat the gear off a standard hyd. cam, go to a wrecker and get a dist. from a 351W.
Old Dec 27, 2003 | 07:04 AM
tracman's Avatar
tracman
I know the Iron gear is what I need for the stock hydr. cam. Just wasn't sure about how to tell what shaft size the one they had was.
think I will take your advice and go to a junk yard today and get one...
tracman
15
Feb 3, 2022 02:54 AM
lmadore
Oct 25, 2005 07:53 AM
pcmenten
Feb 3, 2004 04:23 PM
nick1
Nov 11, 2001 03:10 PM
