EGR makes a difference Bill
Instead of using rudimentary vacuum signals actuate the EGR valve, some newer EGR valves are operated by servo motors, and some systems use multiple valves with various orifice sizes to control the EGR rate even more precisely.
EGR systems for compression-ignition (diesel) engines have been a huge and somewhat controversial topic in the automotive industry over the last year, so there is now a huge volume of readily available information on that subject.
On an older engine design like the 351C/351M/400, with its primitive EGR controls and a vacuum operated valve, the EGR system compromises driveability, power, and economy in the pursuit of NOx emissions control. With the NOx reduction mandates of the early '70s, EGR was obviously the most cost-effective option for vehicle manufacturers.
Here's an interesting SAE article from back in 2001 about an experimental Saab engine that uses up to a 70% EGR rate without disrupting the stoichiometric 14.6:1 mixture.
http://www.sae.org/automag/techbrief...001/techb3.htm
Europe and Japan are starting to mandate EGR and catalytic converters in their own domestic automotive markets, but they have been very slow to adopt even the emissions control standards that the US had in place 20+ years ago, which is more than a little ironic, considering their adamant support of the "Kyoto Protocol."
