Clutch Conversion
Old Dec 21, 2003 | 12:38 PM
strai81's Avatar
strai81
Clutch Conversion
I have a 79 F-150 4x4 with a manual transmission. Have any of converted your clutch to a hydraulic setup? If so, where did you get the kit from.
Thanks,
Steven Y.
Old Dec 21, 2003 | 01:48 PM
78fordman's Avatar
78fordman
I have been looking for my truck, i have always had problems with the linkage. I have not found anything though.
Old Dec 21, 2003 | 03:21 PM
billycsx-t's Avatar
billycsx-t
This site might help you out, guy converted his bronco to hydraulic. http://classicbroncos.com/hydraulicclutch.shtml
Old Dec 21, 2003 | 04:05 PM
Scot's Avatar
Scot
I am using the Dodge setup on my project but you should be able to do about the same (maybe easier) with the Ford setup.
What I did was to weld and brace a piece of 3/16" plate about 5x8" to the left side of the brake/clutch/steering mount. The plate is flat against the firewall and has a hole where the clutch master bolts to.
The location of the hole MUST be the same distance down from the pivot axis as what it came off of.
The clutch master is not directly in front of the clutch pedal. I am using a portion of a brake pedal that will be welded to the clutch pedal to make the offset work.
Old Dec 24, 2003 | 08:05 PM
strai81's Avatar
strai81
Thanks for the tips.
Steven
SideWinder4.9l
Kentucky Chapter
Jan 20, 2014 10:02 PM
SideWinder4.9l
Kentucky Chapter
Jul 28, 2013 09:06 AM
fearpb
New Member Introductions
Jul 19, 2013 01:08 PM
oldrifleman
Modular V10 (6.8l)
May 24, 2006 09:08 AM
Steven m
Apr 8, 2006 11:32 AM
