1978 - 1996 Big Bronco
cruise control not working
Old Dec 21, 2003 | 12:25 PM
jasona5150's Avatar
jasona5150
Question cruise control not working
i have a friend who's cruise control on his 95' bronco quit working, he said that he took all the fuses out & they were all good? any ideas, thanks
Old Dec 21, 2003 | 12:28 PM
bobcf's Avatar
bobcf
http://www.members.shaw.ca/k2pilot/C...iagnostics.doc
Bob
Old Dec 21, 2003 | 12:42 PM
jasona5150's Avatar
jasona5150
thanks a bunch bob, that should help out.
Old Dec 21, 2003 | 02:36 PM
BOJOFASO's Avatar
BOJOFASO
check the brake light switch. it is a multi purpose switch that turns on the brake lights unlocks the torque converter and disengages the cruis control.
Old Dec 21, 2003 | 08:29 PM
Black Ford XLT's Avatar
Black Ford XLT
CRUISE CONTROL
My cruise on my 1992 quit and the culprit was the instrument cluster was bad .It would engage some times but not hold What a pain that was .TR
Old Dec 22, 2003 | 07:58 AM
kevhard's Avatar
kevhard
I have a '95 and when my cruise stopped, it was a simple brake pressure switch, which is located on top of the master cylinder. Just disconnect the plug and look at it. If there is brake fluid in it, you need to replace it. Minimal cost, 2 minute job. Cruise works fine now. Search these forums for more info - that's how I found out about it in the first place. From what I understand, the cruise control needs this switch to work because that is what tells the cruise that you have stepped on the brakes.
Old Dec 22, 2003 | 08:41 AM
1994Bronco's Avatar
1994Bronco
I have a 94 and the clock spring went. I lost airbag, horn and cruise. Check the clock spring behind the steering wheel.
