Help choosing a van.
Old Dec 21, 2003 | 12:01 PM
cadjak's Avatar
cadjak
I am presently driving a '78 Dodge, short wheelbase, B200, 318, 727 Trans. I've put 365,000 miles on it and I'm looking to replace it. I see more Ford vans than any others, so I figure that means something. Plus, I owned a 1970 Chateau Club Wagon, 302, 3 speed manual and the body quality was much better than my Dodge.
I need to buy a used van because of $$.
I've looked at one 2001 power stroke E350XLT but working on the engine looked like it could be a problem and my wife has a hard time with the diesel clatter, so it would have to be gas.
We carry just 2 passengers and our gear. No built-in stoves, fridges tables etc.
what years, engines, trans, models (E150, E350 etc), and options would you recommend?
I don't go off road but do get on some dicey washboard and gravel. Reliability is my first concern.
Thanks,
-cadjak
Old Dec 21, 2003 | 06:01 PM
VanWild's Avatar
VanWild
What type of gear are you hauling?
I recently bought a 96' E-150 Clubwagon, w/5.7L motor. Holds 8 people and tows my boat like a champ. It also works great to take out the back seat and put my motorcycle in it for track days. I got it for $12k used w/38k miles on it inand it is in great shape.
So it really depends on how heavy duty you need. Mine does all I said and then some. If you need something with a little more beef, get yourself a E-250 or E-350 as they are more heavy duty.
Just shop around and you can find them. I got mine from a dealership that specializes in used work trucks, cargo vans, box vans, etc
Old Dec 21, 2003 | 06:30 PM
cadjak's Avatar
cadjak
I'll tell you, I was all set on Fords until I read the problems that seem to plague the late model modular engines. Blowing plugs and head gaskets at low mileages. The issue seem to be with the 5.4 Liter engines. Maybe the 5.7 didn't have it. I read that there was a Horsepower upgrade in 2001. Does anyone here know if the engine problems began then or was reduced then. Having to buy used is scary enough without having to worry that I could need a new $2300 top end.
There are threads on this forum of guys nervous about replacing their plugs. Hey, come on now! If I have to worry about changing plugs I stay with Mopar.
-cadjak
Old Dec 22, 2003 | 03:53 PM
Leo_T's Avatar
Leo_T
I have a 96 conversion van and I like it. The first van I got was the straight six, and if they still made them, I'd probably have one. They're a good engine, and compared to V8's seem easier to work on. I have the 351 V8 now, but I don't have enough miles to comment on how easy it is work on,
Before I bought it, I took off the dog house, and was able to reach each plug easy enough. Vans have alot of good points, working on the engine isn't one of them.
I have a use for mine, so I put up with the extra trouble.
I've heard the newer engines are harder to work on, no experience myself. I have looked under the hood of some cars with the newer type engine, and they don't look very user friendly. Although they do put out more power per C.I.
The only Ford vans I thought were easy were the 1960's model. I wish they would either, bring the engine all the way in, or add more space to th front like a Bronco.
There are special forums that cover engines. Might be worth a look, see. Just scroll up to the top of the page.
Old Dec 22, 2003 | 06:27 PM
jpsartre12's Avatar
jpsartre12
I just picked up a 91 Club Wagon w/302 and automatic and replaced the alternator and voltage regulator in my driveway when it was ~20F outside. It took me about 4 hours only because the connector for the wiring was on the opposite side from the original. I had to rework the harness to get it to reach. Otherwise, it would have been 1 hour tops. Over twenty-five years ago, I worked part-time at a gas station to earn college tuition money. After getting my first professional job out of college, I swore that I wouldn't work on my own cars again. That lasted until last winter when I helped my son rebuild the top end of an LT-1 in his 94 Z28. I found that it wasn't that bad as long as you had company. Now, we work together on both of our Z28 street/strip cars and my tow vehicle.
Old Dec 22, 2003 | 11:45 PM
Leo_T's Avatar
Leo_T
Hi JP,
You're right about having other people around making things easier. I was just commenting about some other trucks being an easier job. I had a friend drop by with his 4 cyl pickup by Yota. When he opened the hood, it looked like easy work in comparison to my van. That being said, I have more of a need for a van,over a pick-up. I still like my Ford though.
Old Jan 6, 2004 | 12:11 AM
03 van's Avatar
03 van
yea and the yota is useless when the wife kicks you out for the night, the van is a home away from home
Old Jan 6, 2004 | 12:19 AM
pfogle's Avatar
pfogle
Any van is good, regardless of brand. My next one will be a 97 or newer E250/E350 with a PSD.
Old Jan 6, 2004 | 12:37 PM
sinjin's Avatar
sinjin
Any concern about the lower hp rating for the PSD in a van application. I'm told no intercooler is why. I don't know much about diesel engines.
Old Jan 6, 2004 | 01:52 PM
jpsartre12's Avatar
jpsartre12
Sounds like there's some experience talking there.
Old Jan 6, 2004 | 07:12 PM
pfogle's Avatar
pfogle
I don't think that the lack of intercooler is all of it, the exhaust is also more restricted on the van. That can all be fixed tho.
Old Jan 7, 2004 | 08:00 AM
cocot's Avatar
cocot
Re: Help choosing a van.
Thanks,
-cadjak
You really can't go wrong with any of them. First figure out if you need a heavy duty van. I know the first iteration of OD trannys had some problems. If it has a C6 don't worry then.
I would say to try to buy a van from an owner/operator (like me) who has owned it since new and properly maintained it. Instead of one from a company that has been thrashed by every teenager they hired.
Old Jan 8, 2004 | 02:13 PM
shorebird's Avatar
shorebird
You don't say what your price range tops out at. I found a 2001 E-350SD V-10 (see gallery) with 21,400 miles a year ago for $21K. I've since put 15,000 miles more on it with absolutely no problems.
Old Jan 8, 2004 | 05:11 PM
cadjak's Avatar
cadjak
I see a lot of one year old vans in the 23,000 to 27,000mi range. I assume they were rentals. It seems a lot of the Ford dealers have them. Most are E350. I like the durability of the E350 but I won't be loading heavy, so the ride might be a bit harsh. My price range is up to 13K. I'm looking for a privately owned, low mileage vehicle.
My local Ford dealer is a joke. I spoke to a saleman who admitted he didn't know much about full size vans. They only had one new one on the lot. I spoke to a service writer and he was just as clueless. I'm just combing the internet and local papers.
-cadjak
Old Jan 8, 2004 | 06:13 PM
pfogle's Avatar
pfogle
I bought my 1992 E150 with a 351 in 2000 with 92k on the odometer. I have since put over 60k more miles on it, and only replace the TPS, IAC, a few vacuum lines, and the ignition switch, and the tumbler. These are all ~25 dollar parts. This has been in 4 years. The ignition switch wasn;t bad we thought it was, there is a rod in the steering column that lacks lube....
