do i have the wrong carb?
Old Dec 20, 2003 | 06:57 PM
littlefoot's Avatar
littlefoot
i bought a holly carb for my 84 f150 it looks almost identicle to the old one. except the new one, the fuel line comes in the side on the front, instead of the front bottom like the old one, and there is a vacuum line on the front of the old one that there isn't a place to put it on the new one, do i have the wrong one?
or should i plug the one vacuum line and try to bend my fuel line (its metal tubing so i dont know if i should attempt that)
Old Dec 21, 2003 | 12:21 AM
LxMan1's Avatar
LxMan1
What is the list number on the front/right side of the choke horn?
It sounds like a universal carb.
Are you talking about the large vac. line that goes on the front bowl? If so, it is just a vapor recovery hose and if you don't have emmisions inspections, you can just block it off.
Jimmy
Old Dec 21, 2003 | 05:48 PM
littlefoot's Avatar
littlefoot
it is a large line in front that goes to the choke i think were talking about the same line, i think the # is 50174 its a little scuffed so i cant really tell, is there a kit that will make my existing fuel line go to the after market carb or do i need to try to bend my fuel line? thanks for your help
Old Dec 21, 2003 | 06:50 PM
LxMan1's Avatar
LxMan1
What I would do is to get a Banjo fitting that goes into the carb fuel inlet. Then get an inline fuel filter and couple the filter to the banjo fitting and the factory line with short pieces of rubber fuel line.
Jimmy
I looked that number up on Holley's website and is doesn't show up. It you get a chance, try to get me all of the numbers off of the one that you are installing and I will try to find out what it is for ya.
Old Dec 21, 2003 | 06:52 PM
littlefoot's Avatar
littlefoot
sounds good, thank you for the advise
Old Dec 22, 2003 | 05:42 PM
littlefoot's Avatar
littlefoot
sorry i thought you were talking about the old carb numbers. the new one has 80457-2 then underneith that it has 2172
another question do you know what size fitting is going to fit the new carb fuel intake
Old Dec 22, 2003 | 06:28 PM
littlefoot's Avatar
littlefoot
and do you know what size brass pipe my fuel line is? im in the process of buying parts but at the store i am uncertain of sizes
Old Dec 23, 2003 | 09:25 AM
LxMan1's Avatar
LxMan1
That is a 600 Holley. I have one myself. Holley makes the correct "Banjo fitting" Did you get this carb used? Mine came with that fitting already in it. It bolted into the side of the bowl and the hose nipple sticks out the front of the carb.
Any Holley Dealer should have the fitting.
You should have 3/8 factory fuel line so get a Fram G3 fuel filter. It comes with 2 short pieces of rubber line. I would get some screw type clamps though, it comes with 4 squeeze clamps, but I don't trust them.
Jimmy
Old Dec 23, 2003 | 01:42 PM
littlefoot's Avatar
littlefoot
i bought it new, i guess i might be missing peices, im working on it today so hopefully i can get my truck back on the road thanks for all your advise and ill let you know how i did.
Old Dec 23, 2003 | 03:11 PM
littlefoot's Avatar
littlefoot
well i just got back from the parts store, im getting closer, i was missing peices. the banjo fitting was missing
Old Dec 23, 2003 | 03:19 PM
littlefoot's Avatar
littlefoot
when i took the nuts off that held down the carb there were no washers, should i put some on when i put the new carb on?
Old Dec 23, 2003 | 03:49 PM
LxMan1's Avatar
LxMan1
I usually do, this will keep the nuts from digging into the aluminum base of the carb. Also, make sure that you tighten them down evenly. Like a wheel, go cross corner and don't overtighten it. I have seen the corners broken off before because they overtightened the carb. Good and snug is all you need. After you get it running and warmed up, you can retighten them again.
Jimmy
PS, Glad I could help and have a great Holiday!!
Old Dec 23, 2003 | 09:01 PM
littlefoot's Avatar
littlefoot
you helped alot, i have everything worked out right now, thanks and merry Christmas
Old Dec 23, 2003 | 10:33 PM
LxMan1's Avatar
LxMan1
Glad to help. Happy Holidays!!
Old Dec 24, 2003 | 04:41 PM
littlefoot's Avatar
littlefoot
well i put the carb on, it runs great at idle, when i drive it a little bit and come to a stop it wants to idle at 2000, i hit the gas and it stays high, should i adjust anything on my new carb?
when i started the truck up it idled high, then i hit the gas to turn the high idle off, and it idled at around 1000rpms, after driving it i dont know what to do.
