Sponsored by: Real Truck
97 460 quits idling
Old Nov 15, 2002 | 10:44 AM
CO4x4SD's Avatar
CO4x4SD
97 460 quits idling
Old Nov 17, 2002 | 07:55 PM
Smile_1's Avatar
Smile_1
97 460 quits idling
Been searching for a while here looking for anything that relates to this and I found one. Anyway, I have a 97 motothome with a 460. The problem is when I start it when it is cold, it will idle for 3-5 minutes then quit. I have tried to increase the idle a little by holding the gas down, but it will still quit after a bit. I also notice that when I release the parking brake, it will sometimes hesistate or quit for a second or two. I've been to several FORD dealerships in my area, north county in San Diego, and on thought it might be a vacum leak because of a cracked exhust manifold, had that replaced, another story, and the problem is still there. From what I can see, the dealers check the onboard computer and if it doesn't give them a fault, they don't know what to do. This weekend we went out and it stalled several times as I was leaving the camp site.
I'm open for any thoughts from you experts out there.
Thanks!!
Old Nov 18, 2002 | 08:29 PM
4x4x4x4's Avatar
4x4x4x4
97 460 quits idling
Tough question.
Hard to even guess since I don't believe this is a common problem.
The best advice I can give you is try and figure out whether it caused by lack of spark or fuel and start from there.
If is equipped with a tachometer and it is ignition related the needle should drop of fluctuate downward rapidly when it stumbles.
I wish I could help more but it's tough to do online.
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
