Sponsored by: Real Truck
What axles?
Old Nov 15, 2002 | 03:23 AM
canada eh's Avatar
canada eh
Post What axles?
What axles are in my 2000 F450 4X4??
Looking to do a gear swap and need specifics
Old Nov 15, 2002 | 05:06 AM
Yeti's Avatar
Yeti
What axles?
Dana 50 front, Sterling 10.5 rear, I found that spicer is the best bet for after market gears. Depending on what ratio you are looking for, some manufactures don't make them for our apps.
Old Nov 15, 2002 | 10:44 AM
CO4x4SD's Avatar
CO4x4SD
What axles?
If you are looking for gears try Drivetrain Direct. They advertise in petersons 4 Wheel and Off-Road magazine every month. They have new super duty kits, front and rear ring and pinions, plus master install kits for $599. They list 4.88 and 5.13 as the ratios available. You can also find 4.56 gears. I want to go with the 4.88's and this is the best deal I have found. Now I need to find someone qualified to do a Sterling rear setup in the Denver area. Good luck with yours!
Oh, I know all SRW trucks had the Dana 50 until 2002. If your F-450 is a dualie it probably has the Dana 60.
Old Nov 15, 2002 | 01:40 PM
Monsta's Avatar
Monsta
Sit. Stay.
What axles?
I think you got a Dana 60 front and a Dana 80 rear but I will double check. You may have a Dana S135 in the back.
Old Nov 15, 2002 | 03:46 PM
Yeti's Avatar
Yeti
What axles?
[updated:LAST EDITED ON 15-Nov-02 AT 04:55 PM (EST)]I should of actually read the topic and noticed the F450, see what happens to me a 6am, glad Im not a surgeon!!:-X23
Monsta I believe your right, Dana 60 Front rates at 6000# / Dana 80 Rear rated at 11,000#
Old Nov 15, 2002 | 04:50 PM
Monsta's Avatar
Monsta
Sit. Stay.
What axles?
I'll second that.
Old Nov 15, 2002 | 06:06 PM
FortyFords's Avatar
FortyFords
What axles?
Coffee Yeti! Black Coffee! for that time of the am !
Geez! I would help ya sooner but!
I was chking the manual and these guys helped you first!
Rich
Old Nov 15, 2002 | 10:42 PM
Quikirk's Avatar
Quikirk
What axles?
Forty, I'm beginnin to think Yeti gets up so early in the a.m. just to beat you to the punch. Ya gotta get a handle on this.
Old Nov 15, 2002 | 11:02 PM
DWRIGHT's Avatar
DWRIGHT
What axles?
Yeah at first I thought you might have taken to the diesel fumes!!
Old Nov 16, 2002 | 07:24 AM
Yeti's Avatar
Yeti
What axles?
>fumes!!
Well as Forty and a few others know, I am a closet diesel lover:-staun
Old Nov 18, 2002 | 01:46 AM
canada eh's Avatar
canada eh
What axles?
OK. I had a 97 F350 Crew cab diesel 4x4 and it gad the Dana 60 front end. The new truck (F450 4x4) has a bigger heavier front end than the old truck. Did Dana build 2 versions of the 60??
Old Nov 18, 2002 | 09:26 AM
Pastmaster's Avatar
Pastmaster
What axles?
I *think* there are actually at least two versions of the D60 front. I know throughout the years they have different ring gear sizes, so perhaps that is the difference?
Old Nov 18, 2002 | 08:34 PM
4x4x4x4's Avatar
4x4x4x4
What axles?
>the 60??
I have an old style and a new style F-350,4x4,SRW.I haven't paid a lot of attention to axle differences.I did observe two obvious differences.
1.The steering linkage is larger on the newer truck.
2.The hub locks (manual) are also different.
Old Nov 18, 2002 | 08:38 PM
billytucker1's Avatar
billytucker1
What axles?
1972RedNeck
Dec 14, 2012 07:18 PM
hatchet
Offroad & 4x4
Feb 29, 2008 03:15 PM
rangerguy52
Jun 29, 2005 03:50 PM
There Goes The Neighborhood
Aug 18, 2003 08:11 AM
Clay911
Jul 4, 2003 05:31 PM
