I have a problem since yesterday. I drove and want to shift in the next gear, push the clutch, shift, let the clutch come and the motor are hauling. I thought i was in the wrong gear and push the ne clutch again and the motor stands.
I cant start beacuse I have no ignition. All consumer that need 12v over ignition dont work. No glowing, no wipes, no electrical windows, no cranking of the motor.
The Motor starting relais is OK but it becomes not the 12v to work, when i turn my ignition Key.
Where is the problem ? The fuses left below the steering wheel are all ok. What can i check next ?
Did anyone have an electrical plan of the ignition ?
Thanks and I hope everyone can understand my question.
Headlights, Hazard Flashers, Brake lights are ok.
But all what working over the 12v ignition dont work. The motor starter ralais themself is ok but not get the 12v start signal to work.
Hmm, when i see it right i must pay there for a look in the wiring diagrams....thats not that what I want....can anybody scan the pages that I need and send it to me via mail ?
Originally posted by stepman Check the yellow wires at the ignition switch for 12v. If you don't have that, look at the fusuble links on the starter relay.
Hi !
Where I can find the ignition switch ? Is it a box on the (I dont know the word exact... i try to explain it) tube where the steering wheel is mounted ?
The above picture is of a gasoline model but the fusible links should be in the same place.I siuspect one of the brown ones may be causing your trouble. one of the 2 brown fuse links are for the ignition circuit.
Thanks for this pic ! In the cables are fuses ? Oh, oh......american cars......and then in germany )
I get out the ignition switch and I have only 5,2V at the 2 yellow cables. Then i searched for the reason and can't find anything. Then i see this pic and went again out to controll the fuses and as i want to cut the first open i see that one of 4 cables is broken (the inner looks out). The 4 cables go in 1 bigger cable. Tomorrow I fix this cable and hope my Ford is running
Thanks @all here at this time. I hope this was my last Topic to this...
