Thinking about a deisel
If I tow just a couple of months a year and just drive the truck around town on short trips, to work etc, the rest of the time,should I get the deisel, or stay with a gasser.
I need some good input here. If this post is in the wrong place, I am sure it will be moved to the correct one.
Thanks in advance, there is alot of knowledge here.
Frank
A diesel has a totally different way of making power happen. There is no throttle plate. There is no coil, distributor, electronic ignition computer, are no spark plugs, no wires to replace every year or two, no points (breakers) or no hall effect thingy... It just meters fuel - DIRECTLY.
The air intake is a straight open hole, with no choke and no butterfly valve. It gets all the air that it wants. All it can take in!!!!
Power and RPM's are determined completely by how much diesel fuel you feed it. You can't have a wrong mixture in a diesel as easily as you can in a gas engine.
You can tweak it for better power.
The only trouble shooting you need to do if anything goes wrong most of the time is to the fuel system. The fuel system is fairly simple. Diesels have better pure grunt power than a gas engine in part due to gearing - and they last twice as long as a gas engine if no one messes it up! 300,000 miles can be gotten from a new or rebuilt engine. Because it's controlled by strict fuel flow management - you can't get a more efficient engine design.
And diesel is usually cheaper than gasoline.
The initial cost of the engines are higher, but they pay for themselves. I use mine as a daily commuter, because my flatbed F250 gets better mileage than my 302 powered F100. I've had a few months to compare them. The F250 is much heavier, and bigger. But it just plain makes better use of it's fuel!
Both of them have C-6 trannies, and the F250 gets through all of its low gears by the time it hits 35 miles per hour.....
If I had a better tranny, it would get incredible mileage compared to the 302, but it's (in cubic inches) a 420. 6.9 liters = 420 cubic inches. If I was running a gas version of one of those, I'd be bankrupt before long.... It's a huge motor to my way of thinking, but it has more pulling power and can nurse it's fuel like a mouse from one of those rodent bottles on the highway.
It don't lack for pulling power! But it can also cruise, even unloaded, better than a small block.
For what that's worth...
I understand now why people say: "Once you go diesel, you won't go back"
I always thought a deisel was built to RUN. I know they are head and sholders above gassers for pulling, both in power and mileage. I just didn't want to wear it out stopping and starting it all the time.
Also, deisel is usually higher in the winter, but there isn't ,much vacation driving in the winter. It goes back down when those folks on the east coast stop using so much fuel oil to heat their homes.
Thanks for the reply.
Frank
If the lights are off - there isn't any stray electricity around it to speak of. A diesel will also virtually "sip" fuel at idle, and they run a hella lot cooler than gas. (More info on hot gas engines later - I have to get some sleep)
~Wolf
One last - on edit:
The starter I bought for my 6.9 came from the parts store with a lifetime warrantee. If it ever quits, I can pull it out, take it to them, and they will hand me another one with no cash involved. So that's conquerable!
(Just kidding) Anyway, for the trailer pulling, the diesel will always be better. The rest of the time, any motor will do fine. We debate this endlessly in other forums but only the buyer can justify whether the added cost of the motor will pay for itself in added benefits.
. . as that is about the only part I have ever heard of failing directly related to starting and stopping the engine frequently.
As you may be able to imagine; if you pull in off the highway, slide up to the fuel pump, and just shut the engine down, that dang turbo may well still be spinning several thousand RMP.
It is failing to delay shutting off the oil pressure to the turbo until it has slowed down sufficiently that causes this "history" of problems with the diesel in this type of use - not the frequent starting and stopping of the engine it's self.
~Always~ let that turbocharged diesel idle for a minute OR TWO before shutting it down, and I truly believe you will not have any problems starting and stopping - all you want.
FWIW & IMHO.
It will keep the the turbo looking like this guy
, instead of this guy
, and then this guy
I am in a pickle. I pull a large travel trailer and will need a new TV in about a year and a half. My questioin is:
Frank
We became full time RV's in 1999 the pickup has been our only vehicle and we would not drive anything but a diesel. The new Fords are so quiet and drive so nice and smooth. We love the new 6.0 diesel it has more horse power than our friends 1999 Ford F350. Big Bob
I don't care for diesels as a daily driver. They are noisyer and rougher than a gas motor and the little things like waiting for the glow plugs to start it and letting the turbo spool down before shutting off wear thin in day to day use. The diesel has different road manners than a gas motor, especially around town. Here too I prefer the gas motor. I would recommend you drive a diesel for a day or two to get a feel for these and see how you like it.
If you do a lot of heavy towing, then the performance of the turbodiesel is better, especially at altitude. Fuel milage and service life are better too. But diesel fuel is sometimes higher or lower than gas depending on what state and the time of year you use the vehicle. Many of the states I tow'ed in diesel was higher and that offset the fuel milage difference. I now figure my milage in "miles per dollar" rather than miles per gallon. That makes a lot more of a direct comparison in fuel cost.
Also, the diesel has a lot higher cost of operation too. Regular serivce (oil change, water separator, fuel filter, fuel conditioner and air filter) is much higher and must be more rigorously adheard too than a gas motor. Check the factory's maintenance schedules for both and compare the costs of each and you will be shocked at the difference. For a V10, changing the oil and filter, air filter and fuel filter is a fraction of the cost of a diesel. Yes, diesel's don't require "tune-ups" like gas motors but modern gas motors can go 50 to 100K miles before requiring one and then its only a set of plug wires, spark plugs and PCV. All done for about the cost of an oil change on a PSD.
A V10 with a Banks kit on it can perform like a PSD in all but the most seviere conditions yet drive around town daily like any car. Yes, diesels will go 300K miles but then so will a well cared for gas motor. My current '95 Clubwagon XLT has 220K miles (mostly towing) on it and is going strong.
For my preferences, I would look at what I needed the vehicle to to best. The more I needed it to tow heavy loads, long distances, the more I would lean toward the diesel. If I needed to use it more as a daily driver that I tow'ed with occasionally, the more I would consider the V10. Also, the difference in purchase price can be pretty stiff too.
Steve
