coolant leak from where????
Old Dec 19, 2003 | 04:07 PM
lilpig88's Avatar
lilpig88
my dad's got an 89 f150 (5.0) and coolant was leaking from under the water pump (on the passenger's side) but not out of the weep holes. i figured it was a bad gasket in the pump. replaced those and it still leaked with a consistent drip. it looks like it's coming from behind the timing cover, but is this possible? no oil or anything in the coolant. i read another post about someone having this problem and it sounds like a leak from behind the timing cover isn't possible (which i was thinking), but my t stat is not leaking and neither is the little bypass hose.
i guess my question is this: can a coolant leak come from behind the timing cover on this motor? (i'm familiar with the FE, not the 302)
any advice or opinions would be much appreciated
thanks
Old Dec 19, 2003 | 06:54 PM
lilpig88's Avatar
lilpig88
anyone? i just want to know if it's possible for coolant to leak from b/w the block and timing cover b/f i start taking the timing cover off.
thanks
Old Dec 19, 2003 | 07:50 PM
EPNCSU2006's Avatar
EPNCSU2006
Coolant passes through the timing cover, so I guess it's possible to leak between there and the block. However, it would more thank likely end up in your oil pan if that was the case.
Old Dec 19, 2003 | 09:02 PM
TheWiz427's Avatar
TheWiz427
EPNCSU2006 i think it would have to be pretty bad to get in the pan, However i think your right as to where its comming from.
Old Dec 19, 2003 | 10:31 PM
lilpig88's Avatar
lilpig88
thank you very much. i guess i'll rip off the timing cover tomorrow.
with 150000 on it, would it be a good idea to just replace the timing chain also? anything else i should look for while i'm in there?
thanks again
