Failed Emissions
Old Dec 19, 2003 | 03:15 PM
4X4BIGDOG's Avatar
4X4BIGDOG
Angry Failed Emissions
I took my 70 F100 in for Emissions testing and it failed the CO% test. Max is 4.50 and it reads 5.65. A little history on what I have done. Cleaned radiator, new wires, dist. cap, points, plugs. Rebuilt Carb. New air filter and PVC valve. Changed oil and filter. New exhsust tail pipe and muffler. All this was done before testing. Any ideas on what to check other than readjust carb and check timing? It has a 302/standard 4 speed/2110 carb. The choke seems to not be working correctly, hard as heck to start cold and won't idle when cold. Old gal has'nt been registered or ran since 96. Runs smooth when warm and I did warm her up good before taking her in. Any help is greatly appreciated.
Old Dec 19, 2003 | 06:21 PM
jor's Avatar
jor
Here's what I do every year to get my 67 352 to pass in Arizona:
* Timing at 5° BTDC (normally it's 8)
* Very lean fuel
* New PCV valve
* Add one gallon of denatured alcohol to 1/2 tank fuel ($9 per gal)
* Set the idle a couple of hundred above normal (maybe 875 or so)
I always feel as though I have gotten away with something when I pass and I usually celebrate with a cold beer. Good luck.
jor
Old Dec 19, 2003 | 09:21 PM
Faithful Old Road Dog's Avatar
Wow! Here in California, a truck that old doesn't need to do the emission test. It was 73 and older vehicles exempt. I think it's now vehicles 30 years and older are exempt. I always thought that California was a pain when it came to emissions. I had a newer vehicle (79) that I needed to pass emissions. 2-3 blocks before I got to the smog station, I changed the metering rods in the Edelbrock carb to lean it out. After passing the test, I drove a few blocks away and changed the metering rods right back.
Old Dec 19, 2003 | 11:41 PM
4X4BIGDOG's Avatar
4X4BIGDOG
Thanks guys. I have seen the one about the denatured alcohol a couple of times. Gonna give it a try. I readjusted the carb and reset the timing, was off pretty far. If I can just pass this one time, the old gal will be exempt from now on. And a cold one will be in order for sure.
Old Dec 20, 2003 | 01:24 AM
rainbowATF's Avatar
rainbowATF
Ohio E-check
For those Ohio counties with E-check. It is 25 years. There are exemptions for cars with $200 in emission repairs (owner labor doesn't count) and income exemptions. Bought 1979 F100 at end of October had to have e-check for only 8 weeks. Jan 1, 2004 no more emissions check. Passed with new air check valves and new cat and tuneup.
Old Dec 20, 2003 | 01:08 PM
ACESN8S's Avatar
ACESN8S
What's an emissions test?
Just kidding, I just haven't had to have one done for so many years....
Plus it also helps to live in a county where there are NO emission tests, or inspections.
Old Dec 20, 2003 | 01:27 PM
Mike W's Avatar
Mike W
Check for a vacuum leak.
Old Dec 25, 2003 | 10:05 PM
baitmaster's Avatar
baitmaster
emissions tips
Since I dropped rebuilt 390 into my xlt it passes emissions easily. My old 390 would pass, but I always helped it out by throwing in a can of emissions passer a few days before, turning idle screws in as far as I dared, and setting idle up to just below 900. (Manual tranny). Make sure your spark plugs are clean and get the motor as hot as possible. (Hotter thermostat or run the air cond right up to hooking machine up to truck. Make sure the gas is fresh, it gets stale pretty fast these days.
2trux
1983 - 2012 Ranger & B-Series
Oct 25, 2014 12:23 AM
Ed_B
Jun 25, 2007 04:12 PM
afunk
Jul 20, 2006 06:06 PM
JimFraser
Ontario Chapter
Feb 17, 2004 07:43 PM
rwsam
1978 - 1996 Big Bronco
Jan 6, 2003 11:59 PM
