Well, I can now say, I drive a pickup truck. I drive a ’99 4wd Ranger XLT Style Side with the extended cab! It has the 3.0 and the automatic and only 32k miles!
I finally got my Ranger legal for road use. My first trip after the legal formalities was to get an extra ignition and door key cut at a hardware store.
I was in for a surprise! Not being astute enough to fully read the owner’s manual, I found out the hard way that these keys seem to have a micro-chip inside them. The key worked fine opening the door, but when inserted and turned inside the ignition, nothing happened.
According to the guy at the hardware store, this could have burned out the ignition switch if I had prolonged my attempt to start the engine. Is this true?
At least the door key will get me inside the truck if I lock my keys inside!
You know when you're a rookie when you go to gas-up and you don't know which side the truck loads on.
To answer the one question you seemed to ask....I doubt seriously that the attempts to start your truck would burn anything.
When the computer/passlock does not find teh chip, I would not think current of any kind is going through the ignition system.
When I got my 94 Ranger after spring break, I had to quickly get used to gassing-up on the opposte sidethan what my Isuzu truck had....
Oh yeah, I have a security type chip that was installed by my friend's dad when he still had the truck for his company. I pull it out and I don't think the radio turns on when I try to start the truck. If I lose that chip, I am major-league f-cked.
good luck with the new truck i have 76K on my 99 ranger with a 4 banger and it runs great even tho i beat on it regularly
keep changing that oil and youll get these fords to run forever
Not true. I don't like to go into details on how the system works since you never know who might find the information, the key sends out a signal like a remote so there's no direct connection.
Moms' 98 Crown Vic owners manual gave detailed instructions on how to "program" a spare chip key. Did it myself in the dealers driveway.
Check your owners manual for similar instructions.
Does anyone know what year Ford started using ignition keys with chips in them in Rangers? If your key has a plastic coating on the grip end of it, does that mean it has a chip in it? My '95 owner's manual says nothing about a chip in the ignition key.
It seems to take a certain touch to just turn either door key and get the lock to unlock. I'm learning it!
Being a real newbie, I don't have a clue when the chip years started. I gave my manual a quick read and it said nothing about this chip business.
I found out the hard way! If someone out here also has a 1999 and finds this chip business printed in their manual, please enlighten us with the page number. I'd like to read up!
I plan on keeping a chipped key hidden inside the truck and carrying the extra "for entering only" key handy. I figure if I need to get into the truck I'll be covered. If I've misplaced the ignition key (Ouch!) then I'll locate the hidden key and be on my way.
Originally posted by Flexfuel-Dave Another thing I've realized about the keys are their inability to turn the door locks.
Do any of you folks have this trouble?
The key slides in fine, but I have to twist it back and forth a few times before I can get the unlocking postion.
Does this just sound like a badly cut key or is this a common issue this these vehicles?
Thanks everyone!
I have a 93 Aerostar that I drove for 9 years with this problem until one day I used the original spare key. The lock opened with no fuss. Then I looked at the two keys side by side and lo and behold the key that I had been using all these years was not cut in some spots. Ford did not finish cutting the key. Try the spare key and see if it works better. If it does, you have a bad cut key. LOL guys.
The "securilock" is on page 68 in my 1999 ranger owner's guide.
This will tell you how the chip works and what you have to do to get a new key. (you have to take it to a dealer)
