Sponsored by: Real Truck
5.4 RPM'S While towing
Old Dec 19, 2003 | 08:57 AM
angusjohn's Avatar
angusjohn
Lightbulb 5.4 RPM'S While towing
I recently bought a 2001 f350/5.4 to tow a 18' cattle trailer. On county roads not going into overdrive I push a little over 3000rpms at 63mph. The truck pulls fine I was just wondering if this motor was made to run at high rpm for extended periods, or if this is even high rpm's for this motor. Thanks, this is my first post.
Old Dec 19, 2003 | 09:22 AM
kehale's Avatar
kehale
that's not really high RPM's for that motor.
Don't expect good mileage, however.
The little 5.4 really sucks some fuel when towing (as do most gas engines)
Your best bet is not to "lug" the engine. Engines generally don't like that much.
-T
Old Dec 19, 2003 | 11:53 AM
NoMo's Avatar
NoMo
Welcome to the site angusjohn!
Unlike the engines of old, these new overhead cam engines are made to rev high and stay there. As kehale said; running 3000 RPMs is no big deal. Redline is about 5500 RPMs and the full-throttle shift point is 5200. So, DRIVE ON!!!
Old Dec 19, 2003 | 01:20 PM
carter1's Avatar
carter1
I pulled my boat last weekend (about 3000lbs), it turned about 2800 at 65mph with overdrive disabled. Gas mileage dropped to less than 10.
Old Dec 19, 2003 | 01:21 PM
carter1's Avatar
carter1
By the way-I have a 3.73-no limited slip.
Old Dec 19, 2003 | 02:16 PM
angusjohn's Avatar
angusjohn
Thanks for the input. I never knew shift pts were that high. I always had trouble going from third to fourth with a lug but I never pushed it over 3500 rpm. You are right with a trailer milage falls. I have stated to run Mobil Synthetic and put in a Kool-Blue filter helps some.
Mine is 4.10 limited slip with manual trans.
Dumprat
May 4, 2016 08:18 AM
jereli
19
Jun 19, 2015 11:51 AM
PauL3861
May 25, 2015 06:08 PM
adam10
Apr 17, 2015 06:10 AM
Black79
Oct 18, 2013 04:41 PM
