power locks
Old Dec 19, 2003 | 07:16 AM
Amys Truck's Avatar
Amys Truck
power locks
I have a 93' 350 crew cab XL. It does not have power locks BUT I need to put them in. Does anyone know if my truck is prewired for them and also, what kind of motor I need to run them? I am very mechanically inclined and am looking for some direction as the Ford dealership wants $100 to just look at my truck and tell me if it is prewired. A part number for the motor would be great! Thanks! Amy
Old Dec 19, 2003 | 12:19 PM
charlez's Avatar
charlez
I have added power locks to my '93. I can almost guarantee there is no factory wiring in place. Here is by far the most cost effective way to add power locks. I would reccomend a generic aftermarket kit. These can be purchased off Ebay for $30 or less. (search power lock kit ) These kits are fairly simple to install. First you mount the unit in the door. You just have to drill a couple holes and bolt them in. Next, there is a extension rod with a clamp on it. This clamps the motor rod to the existing lock rod. I installed the cheapest kit I could find and it has worked flawlessly.
If you want to go with oem parts you can do that too. The oem
actuators look like they go for about $60-$70 each. You will also have to come up with a plug to connect to the plug on the oem actuator.
Either way you will have to do some wiring. It is a pretty simple setup depending on what switches you are using.
If you need details on the wiring, let me know what type of switches you will be using.
n6nfg
6.7L Power Stroke Diesel
13
Oct 21, 2013 03:15 PM
Olds69442
23
Jun 8, 2012 09:00 AM
