E250 Overheating
Old Dec 18, 2003 | 10:15 PM
Paul Lazarro's Avatar
Paul Lazarro
E250 Overheating
E250 overheated on Wednesday and had it towed to the dealer. They said the T-stat was stuck closed and they replaced it.
Next day...same story... going up same hill...overheated...check engine light comes on...coolant leaking out of the fill reservoir. Towed it in again...now they say the radiator is 25% blocked and they say they will put a new one in tomorrow.
Is this possible? Year 2000...59,000 miles...always serviced regularly.
Any thoughts?
Thanks
Paul
Old Dec 18, 2003 | 10:21 PM
Ultramagdan's Avatar
Ultramagdan
Hello Paul and welcome to FTE!
How do they know the rad is 25% blocked??? I would ask for some clarity on that. Have you changed the coolant prior to this? Seems odd to me.
Old Dec 18, 2003 | 10:30 PM
Paul Lazarro
Dan
Thanks for your reply. Sounds odd to me also. As I said, only 59,000 miles on this van, regularly serviced, coolant always tested fine.
The service mgr told me they took the radiator out and had it tested at a radiator shop. Said they are going to put a new one in tomorrow to the tune of $460.00.
Am I missing something here? Could there be some other problem that they are mis-diagnosing?
Paul
Old Dec 19, 2003 | 03:42 PM
L_Lucas's Avatar
L_Lucas
Yes, there could be other things causing it to overheat. Too rich, too lean, timing too retarded or too advanced. Hopefully your dealer checked these things first, before starting to swap parts.
Old Dec 20, 2003 | 02:26 PM
Paul Lazarro
Now has a New Radiator
They put a new radiator in yesterday and told me it's working fine now. I asked them to give me the old one.
I plan to open the old one up. Will I see a physical blockage?
Thanks
Paul
Old Dec 20, 2003 | 04:24 PM
Ultramagdan
At 25% blockage I would expect to see something. Depending on how you cut it apart it may be difficult to see stuff but 25% should be enough to show buildup.
Let us know what you find.
S.P.
Sep 5, 2016 10:05 PM
fergie1111
EcoBoost (all engine sizes)
43
Sep 27, 2013 01:28 PM
paweliania
Jul 9, 2013 09:59 AM
PAUL_2
Aug 27, 2003 06:10 PM
Mar 11, 2001 10:13 PM
