1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
alcoa rims for f-250
Old 11-19-2002, 08:12 PM
Y2K350's Avatar
Y2K350
Y2K350 is offline
Old 11-23-2002, 02:53 PM
rvm264's Avatar
rvm264
rvm264 is offline
Hi, I have a couple of questions, 1st what is the weight rating of the stock aluminum xlt rims for a psd. 2nd A friend recently gave me a set of alcoa aluminum rims 16x7 rated for 3042lbs, so I can mount a set of snow tires. these rims have the countersunk type lugs, can I use these on my truck? I own a 02 250 psd sc LB 4X4. Can I just buy new set of lug nuts?
Old 11-23-2002, 08:05 PM
4x4x4x4's Avatar
4x4x4x4
4x4x4x4 is offline
Good rims.They should be made out of forged aluminum.They are quite sufficent as far as the load rating is concerned.
these
>of lug nuts?
Now the bad news,I don't believe they have the same bolt pattrern.I personally wouldn't deviate from the original lug design that your truck uses.
Old 11-24-2002, 05:52 PM
ColtM4's Avatar
ColtM4
ColtM4 is offline
I don't think you can use the wheels on your truck. The SD's have 2 piece lug nuts and counter sunk wheels I think use 1 piece lug nuts. That aside, the SD wheels are Hubcentric, meaning load is placed on the wheel hub vs. Lugcentric where the load is taken by the lug nuts/axle studs. I could be wrong but if you go to the alcoa wheels website more info is available there. BTW, stock aluminum wheels from ford are manufactured by Alcoa.
Old 11-24-2002, 06:16 PM
rvm264's Avatar
rvm264
rvm264 is offline
thanks for the help. I appreciate it.
Aerostar
05-16-2024 11:55 AM
bradphx
67
01-10-2024 06:12 PM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Oklahoma Chapter
04-11-2003 10:33 PM
walterdanek
16
02-16-2001 07:56 PM
Quick Reply: alcoa rims for f-250
