Diagnostic Port Location
Old Dec 18, 2003 | 04:08 PM
shabah222's Avatar
shabah222
Can anyone tell me where the diagnostic port is located on a 1996 F250? I am thinking about getting a Superchip microtuner to reprogram the chip but I want to make sure I know where the thing plugs in before I buy it.
Thanks.....
Old Dec 18, 2003 | 04:17 PM
natewoz's Avatar
natewoz
Within 3 feet of your steering collum (Required by law, OBD-II mandate). Most likely under the driverside dash. Mines an OBD-I so I cannot tell you exactly were it's at, but I should be right.
Old Dec 18, 2003 | 05:14 PM
StrangeRanger's Avatar
StrangeRanger
Just below the ashtray
Old Dec 18, 2003 | 07:16 PM
shabah222's Avatar
shabah222
Thanks very much to both of you
Old Dec 19, 2003 | 06:46 PM
shabah222's Avatar
shabah222
Actually guys......I didn't find anything inside the cab of the truck (either under the dashboard or ashtray) and I was upside down under the dash trying to find it.......I did find a plug in the engine compartment on the firewall that says 'EEC Test' (a "D" shaped plug) that I assume is a diagnostic connection.... Can't find anything in my Haynes service manual (like that's a surprise) about it...
Old Dec 19, 2003 | 07:54 PM
MustangGT221's Avatar
MustangGT221
I thought the port below the ashtray was for the electric trailer brakes?
Old Dec 20, 2003 | 08:09 AM
StrangeRanger
On a 96 with OBD-II the diagnostic port was relocated to the interior by the gov't. Mine's at the bottom edge of the I/P about even with the right end of the asytray. The older models had it in the engine compartment
Old Dec 20, 2003 | 10:34 AM
fordin K's Avatar
fordin K
strage guru is right on that, but on some fords for some reason (like some mustangs) they are located facing sideways out of the center console about the rear of the radio distance back so you gotta really look. it is normally black and compact. the old EEC one you are talking about was on pre-96 vehicles right next to the hood hinge (driverside) fender, inside compartment of course. and about 2x the size fo the new SLC connector
Old Dec 20, 2003 | 07:14 PM
shabah222's Avatar
shabah222
So even though my truck is titled as a 1996 model, I could assmue that it was built and sold before the government mandate was effective....possibly late '95....? If so....does this also mean that the Superchip 1715 microtuner will not work with my truck?
Old Dec 20, 2003 | 10:35 PM
StrangeRanger
Since it's an F250, the OBD-II regs might not apply to it. I'm not sure when they applied to over 8500 GVWR. If the connector is under the hood, for sure it's OBD-I
Old Dec 21, 2003 | 08:12 AM
shabah222's Avatar
shabah222
That's what I figured...thanks for the info....
standley20
Dec 31, 2013 10:19 AM
hopewell
Oct 19, 2013 08:57 AM
fourdoordemon
Jul 24, 2009 12:59 PM
casca2063
Sep 23, 2004 08:00 PM
shabah222
Computer Chips & Tuners
Dec 28, 2003 11:36 PM
