Brake problems!!!!
Old Dec 18, 2003 | 03:52 PM
motobub's Avatar
motobub
Brake problems!!!!
1991 F-250 4x4.
I was driving and they worked fine, then all of the sudden they didnt work and the brake light came on. The fluid did not leak out. The pedle is still firm and doesnt go to the floor. It felt like the back ones worked a little.
So I changed the master cylinder today and bleed all the air out of the system. Now the pedle is firm again and I thought I fixed it, untill I took it out for a drive, and its the same thing. The pedle is hard, there is no air in it. And the back brakes work, but nothing from the front.
Whats wrong?
Thanks,
Lars
__________________
Old Dec 19, 2003 | 02:28 AM
willd's Avatar
willd
Sounds like the proportioning valve failed. If you get a leaky line, or the spring breaks inside it you can get only front or rear brakes. I had one that froze up over a winter of non-use. I only had front brakes till I finally figured it out. Only took me a couple of months and several hundred in new parts.
Old Dec 19, 2003 | 11:15 AM
motobub's Avatar
motobub
Where is the proportioning valve? I thought thats what it was too, but couldent find one. I found some sort of valve in the brake line that goes to the rear brakes, it had 4 wires going into it, and a bleeder valve on it. But it isnt connected to the front brakes at all. Is this the Anti-lock brakes?
Lars
Old Dec 19, 2003 | 12:15 PM
wildjon300ci's Avatar
wildjon300ci
Lars
Yep, that's your RABS.
The proportioning valve is on the drivers side under the hood right next to the framerail. You can follow the coil of brakelines to it if you can't find it. It has a wireconnection on the top.
Old Dec 19, 2003 | 12:42 PM
motobub's Avatar
motobub
I couldent find it, all I can think of is that it is in the mastercylinder.
Old Dec 19, 2003 | 10:55 PM
f100guy's Avatar
f100guy
no the lines that come out of the master cylinder go straight to the proportioning valve. you can't miss it. it has all kinds of steel brake lines coming out of it
|WYG|SS
Nov 16, 2015 06:54 PM
olfordsnstone
Jul 12, 2008 01:09 PM
Carltmon
New Member Introductions
Aug 2, 2007 02:02 PM
DW2455
Sep 18, 2004 02:09 AM
motobub
Offroad & 4x4
15
Dec 22, 2003 11:59 AM
