intake gasket
Old Dec 19, 2003 | 03:09 PM
Henry_the_Ford's Avatar
Henry_the_Ford
I never use the gaskets....no problems.....
Old Dec 19, 2003 | 04:35 PM
79oneton's Avatar
79oneton
some one said the old fashion black permatex, this is the only way to do it once. I couldn't agree more
Old Dec 19, 2003 | 07:51 PM
andrew143's Avatar
andrew143
I'll let you what happens?
Old Dec 19, 2003 | 08:11 PM
Henry_the_Ford
Yep, black permatex is what I use....its the best.
Old Dec 19, 2003 | 09:51 PM
MatthewP's Avatar
MatthewP
I've always had leaks with permatex, and never had leaks with the cork end gaskets (and permatex at the corners). I know this is a heavily debated issue and I'm not going to get into a debate, just relating my own experience.
-Matthew
Old Dec 20, 2003 | 08:00 AM
olfordsnstone's Avatar
olfordsnstone
I have always used the gaskets with the permatex at the corners as well and never had problems. It is interesting to me that so many have used a thick bead like this thread indicates. I have always been told that it was a bad idea to use permatex in that fashion as burned valves are an unacceptable consequence. I guess that experience shows otherwise so I will keep this open as an alternative to failure of the standard way in the future. Good information for me. Consider me educated.
T
Old Dec 29, 2003 | 09:29 PM
andrew143's Avatar
andrew143
Well the intake is on I used the cork end gaskets and used the permatex to hold them down with a small amount at end of the cork gaskets and torqued the bolts down to specs so far so good no leaks yet? Thanks for the input. Andrew
Old Dec 29, 2003 | 11:43 PM
1976BeaterF150's Avatar
1976BeaterF150
I would look up another brand of gasket, perhaps get some serious race gaskets if you cant get your permatex to stick, personally i have never had a problem with Mr.Gasket and orange RTV on both sides of it
Don
