body swap
Old Dec 18, 2003 | 01:12 AM
dreamtruck's Avatar
dreamtruck
Question body swap
I have a perfect 68 f100 2wd and want to drop it on a rusted out 77 f250 4wd frame and runnig gear will the cab mounts a core suppot even be close??:
Old Dec 18, 2003 | 07:21 AM
lastchance's Avatar
lastchance
I can tell ya for sure the cab and front clip are going to bolt on with no modifications (Because that's all the further I've gotten putting a '67 body on a 74) but it seems to me that I've read a couple times here the bed may require a little drilling.
Old Dec 18, 2003 | 09:20 AM
plowpusher's Avatar
plowpusher
measure the width of the rear frame I bet on your older truck it;s the same width as your 77 f-250 if it;s an early highboy style frame width was one of the things changed in 73 for the rear fuel tank on all trucks except the f-250 4x4,s thyey didn't get the frame change till mid-year 77 hence the 77.5 model desination you see referd to all the time
