Bolt hole cracks....
Old Dec 17, 2003 | 10:04 PM
Maurice's Avatar
Maurice
Tell me, is it common for bolt hole cracks to delelop where the steering box bolts to the frame?
Old Dec 17, 2003 | 10:51 PM
sparky's Avatar
sparky
In my experience yes...especially on the 1/2 ton 4x4's...I have actually seen triangular pieces of frame missing from around the bolt holes
Old Dec 17, 2003 | 11:29 PM
wick246's Avatar
wick246
Yes this happens quite a bit. There are patch kits which weld to the frame and repair / strengthen the area.
Old Dec 18, 2003 | 06:11 AM
F150daniel's Avatar
F150daniel
and get a pro welder to weld it on.
Old Dec 19, 2003 | 02:55 PM
dfisher1's Avatar
dfisher1
Mau,
This is a problem. Not only on the 1/2 ton fords but on the 1/2 ton dodge trucks as well.
If its not too bad yet you may get away with welding thick washers over the effected areas. I am a fan of using a one piece plate, the thicker the better. 3/8" is usually more than adequate But remember, you've got to cut it! I clamp it down, somehow and cut it with a sawsall. Put the steering gear against it and mark your holes, then drill.
Got to run.
KingFisher
Old Dec 19, 2003 | 04:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
Chebys are afflicted also...
Old Dec 19, 2003 | 08:23 PM
bigf150's Avatar
bigf150
Yeah it usually happens. What i did on my truck to fix it was i welded the cracks shut then i welded a whole peice right over the whole frame to bolt the steeringbox to.
