what goodies would you put on your truck..to customize it to any way you liked? go fast goodies 4x4 mods anything... mine would be a 5.4L or 351W that had all the lightning goodies... a mean sound system... silver with a black racing stripe... some offset wheels with the widest rubber i could find... dual exhaust running out the rears... a change over of rear gears from the ones i have now... and drive it like it was a hot shelby gt 500 kr with the 429... the only other thing that i think would be nessisary would be the drag chute on the back... just in case i got myself into a hairy situation...
My truck w/ 9" skyjacker lift, Dana 60's front and rear, 4.56 gears, ARB's on both ends, 2" body lift, military olive drab paint scheme, 12k lb hydrolic winch in front 10000lb electric winch rear mounted on a reciever so I can take it off, 460 EFI w/ 8psi supercharger, my tranny (np435) w/ centerfource dual friction clutch, NP205 T-Case, and of course 19.5x44" Boggers.
Stock height, maybe a little lower (not excessively), big drag radials out back with a 550 ft*lb small block and an overdrive trans rocking a 3.70 differential, so you can lay waste to imports, and most ill-fated camaros both off the line AND on the highway! Fast, mean, and efficient!
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
the rest of the running boards, rims, tinted glass, roof lights, wheel flares, window flares, a decal on the back topper window, chromed rear bumper, nice body strip, sub/amp, and air conditioning
